Hello,
I am doing experiments and need to convert some video only. Can you some one please point me in the right direction. If you can provide a step by step that would be great.
Here is the original (From Media Info)
General
Complete name : Raw-2009_05_21-14_51_08.m2t
Format : MPEG-TS
File size : 159 MiB
Duration : 49s 382ms
Start time : UTC 2009-05-21 14:51:08
End time : UTC 2009-05-21 14:51:57
Overall bit rate : 27.0 Mbps
Maximum Overall bit rate : 33.0 Mbps
Encoded date : UTC 2009-05-21 14:51:08
Video
Menu ID : 100 (0x64)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High-1440
Format settings, Matrix : Default
Bit rate mode : Constant
Bit rate : 24.8 Mbps
Nominal bit rate : 25.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Standard : Component
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.532
Stream size : 146 MiB (92%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 49s 128ms
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : 105ms
Stream size : 2.25 MiB (1%)
I need it converted to this exactly. I tried it in Vegas but it will not let me change the frame Rate.
General
Complete name : 1mbps.264
Format : AVC
File size : 1.17 MiB
Video
Format : AVC
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Width : 1 280 pixels
Height : 720 pixels
Frame rate : 15.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Thanks in advance for the help.
from an HDV source vegas can come close using the mainconcept avc encoder. the only thing it doesn't have is a baseline@2.1 setting - the lowest it will go is baseline@3.1 as for the framerate it allows 15fps without any problem. did you have the "allow source to adjust framerate" checked?
here's a sample. use mediainfo to check it's specs.
testchart.mp4
mediacoder can produce the specs you want, even the baseline@2.1
right vegas can't do it.
what is the source video from?
mediacoder can. import the video. set video/format to h264. set encoder to x264. set profile to baseline. set level to 2.1. set your audio. in the "picture" tab, check resize and set it to 1280x720. check frame rate and set it to 15.--
thx I will give it a shot. The video is a test video for a HW decoder that only works if the specs are met.
720p source or downsize 1080p to 720p ?
By vcddude in forum Video ConversionReplies: 4Last Post: 19th May 2011, 18:40 -
What's the BEST way to convert HD .m2ts (720p) to a HD .mp4 file (720p)??
By elgy in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 15th Jan 2011, 19:03 -
2 x 720p AVI with DTS - need 1 x 720p MKV with AC3
By snadge in forum Video ConversionReplies: 2Last Post: 25th Oct 2009, 12:38 -
UNDERWATER VIDEO - Should I get a still-cam with 720p, or a 720p camcorder?
By v1ru5 in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2009, 02:49 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 19:23
