VideoHelp.com Forum
    Recently all flash video sources I access are silent. The video plays, but no sound. This started well after I'd installed Flash 9 (since updated to 10). Happens in both FF3 and IE. I've searched for suggestions, checked through Mozillazine, but no joy. I've uninstalled and re-installed Flash Player, no difference. Running XP Pro SP2 on a P4 2.53 Mhz CPU. 2.5 GB Ram. Sound card works fine, plays everything else.
    Any thoughts or pointers?
    Always code as if the one who winds up maintaining your code is a dangerous psychopath and knows where you live.
  2. Member Krispy Kritter's Avatar
    For Firefox:
    1. Click your start menu and enter: Regedit.exe in your search bar and run it.
    2. Navigate to: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertySt ore
    3. Press CTRL+F and enter firefox.exe
    4. In the bottom of the window, you will see the full key name containing the firefox entry. It will be similar to:
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertySt ore\f8ef7687_0
    Right click that key in the left pane of Regedit and delete it.
    5. Enjoy your audio."
    Google is your Friend
  3. Member Krispy Kritter's Avatar
    You may also want to check the flash settings.
    http://www.mydigitallife.info/2007/0...rnal-websites/
  1. Replies: 4
    Last Post: 9th May 2011, 23:56
  2. Capturing audio from internet flash videos
    By kbark in forum Newbie / General discussions
    Last Post: 7th Mar 2009, 00:13
  3. Replies: 3
    Last Post: 11th Dec 2007, 19:07
  4. Flash audio problem
    By Digiface in forum Audio
    Last Post: 1st Aug 2007, 19:19
  5. Recording audio from Flash website
    By Ryosuke_Gunma in forum Audio
    Last Post: 27th Jul 2007, 13:14
