Does anyone have any suggestions for a good piece of software that will allow me to play 2 video files at once?
I'm experimenting with different filter settings and it's kind of difficult switching back and forth between video files.
Any help would be much appreciated!
Results 1 to 9 of 9
Person Quote: Don't take a dump on my fun.
you can play multiple instances of the same video file by using VLC media player.
Oh, I'm looking to play multiple instances of different video files.
Play file 1 and file 2 at the same time, side by side.Person Quote: Don't take a dump on my fun.
You can do that with most video players. In Media Player Classic, under Options, Player, set to open a new player for each media file played.
Originally a member since 2001, LONG LIVE TARAN's!!!
Great thanks for all the help!
That's not quite true, poisondeathray,
Make an AVISynth script with 2 (or more) source files and use a PIP/tile function.
You could also use a 2-file-aware player, like Stereoscopic player. (It's not necessarily meant for what you want to do, but who cares, it'll still work correctly)
Or, even mux 2 files together (with the old AVIMux v.4 or Graphedit) and play them with MPC, MP6.4 etc.
One controller will control BOTH windows.
I have a couple of stock scripts that use the stack command and various cropping methods to do side by side comparison when doing restoration work. I have posted these before in the restoration forum
Combining Srt files into one for the purpose of authoring a DVD
By isobel in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2010, 06:48 -
Is there a program to schedule time for playing video files
By Chewbacco in forum Software PlayingReplies: 2Last Post: 19th Dec 2009, 05:21 -
General Purpose Video Files
By AndyPerry in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2009, 22:27 -
Video Capture setup fit for dual purpose? could do with some advice.
By brek in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2008, 04:25 -
Program to view 2 synchronized videos simultaneously for quality comparison
By miamicanes in forum Video ConversionReplies: 3Last Post: 13th Sep 2007, 11:25
