Hi all
I have just purchased a Samsung SMX-F30 which I am very happy with, especially as it reords to MP4 H264 and has a 16:9 recording mode.
I use iMovie HD to put together my creations (family videos etc.) and I have been using it for several years and I'm very happy with what it can do and am comfortable with it.
Here's the prob - when I record in 16:9, the file it creates still looks like a 4:3, but with the image horizontally squashed - and it stays that way if i drop it into imovie.
If I use the Cyberlink software that came with the camera on my PC, it looks fine, in glorious widescreen.
Am I right in thinking that the cyberlink software just 'stretches' the image out??
I can use ffmpegx to do the same thing but the quality seems to drop drastically - can I just alter the dimensions without altering the quality?? (e.g. a 7mb file drops to 1mb)
I hope you can make sense of what I have put here!!
Any questions, please feel free to ask.
Thanks in advance
For using widescreen footage in iMovie, first open/start a 16:9 project, then import the video. When starting with a 4:3 project, you often can't use 16:9 anymore.
To check on any stretching of video, you need to know the true resolution (pixel width and height). I suggest MediaInfo Mac, as it gets a all the details of just about any video file.
It is common for SD (standard definition) material to stretch for widescreen, e.g. like DV and DVD MPEG-2.
MP4 allows for stretching video to 'any' display aspect ratio, but the player/decoder has to have support for reading that setting. Unfortunately, QuickTime doesn't have the best track record on that.
Does VLC display your source file in the correct aspect ratio?
The problem is that the Samsung is not setting the wide-screen flag properly. I find my MX20 does the same thing. I run the video through MPEG Streamclip and alter the resolution there so there's no wide-screen flag; the footage is actually now the correct proportion.
How to convert a video without wasting file size and reducing quality?
By tendra in forum Video ConversionReplies: 2Last Post: 29th Oct 2009, 06:24 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 11:01 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 19:22 -
Reducing frames with Staxrip
By jaysonp in forum Video ConversionReplies: 3Last Post: 4th Mar 2008, 10:32 -
Help with reducing size
By gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 13:17
Statistics
Newest guides
Latest tool updates
New media comments
