VideoHelp.com Forum
    Hi All,
    On one particular DVD I always get a "System.DivideByZeroException" when trying to run VOB2MPG v3.0 PRO.
    Full text is:
    Version: VOB2MPG PRO
    Build: 3.0.0024
    Type: System.DivideByZeroException
    Source: VOB2MPG
    Message: Attempted to divide by zero.
    InnerException:
    StackTrace: at VOB2MPG_PRO.IFO.xe679539bc4bbd8b5.xbb0efbbdf7e1b0f d(UInt32 xcb77389a20f86e3f, UInt32 x814e1b25a874e6b0)
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.xe8f3abafd907f7d4(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Any Suggestions?
  2. Member ChrissyBoy's Avatar
    Can you zip up and attach the *.IFO files for this DVD please?
    Thanks for the response. Files emailed to you.
  4. Member Mudmover's Avatar
    Strange that the very next disc I tried to extract gave me the same error...
    Build: 3.0.0024
    Source: VOB2MPG
    InnerException:
    Appropriate files attached too.....
    Right, really must get packing!
    Ta.
    ifo.zip
  5. Member ChrissyBoy's Avatar
    I have fixed this. Will get a build out ASAP
  6. Member ChrissyBoy's Avatar
    Build 3.0.0030 resolves this issue.
  7. Member Mudmover's Avatar
    Yep,
    seems to work fine now - thanks.
  1. VOB2MPG Pro - System.IndexOutOfRangeException
    By ivortheengine in forum SVCD2DVD & VOB2MPG
    Last Post: 12th Sep 2011, 17:18
  2. VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
    By Rich_A in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd May 2011, 15:06
  3. Vob2mpg pro
    By Midnite in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Sep 2010, 08:04
  4. Vob2mpg pro
    By cowboyup910 in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Jul 2010, 07:03
  5. Unable to install VOB2MPG or VOB2MPG PRO
    By tooc in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 00:53
