I saw in the store 720 mb and even 830 mb blank Cds. I don't understand how this can be since the outside diameter of the plastic disk is fixed to a standard. Can someone please explain this.
Results 1 to 10 of 10
Thread: Question about 830 mb blank CDs
The spaces between the data is narrower.
Ritek made 90min and 99min CD-R but they are hard to find nowadays,most writers and players supported the 90min CD-R's but the 99min ones were a crap shoot because of the high tolerances required.Having problems ripping a DVD? Read my guide
I thought the foil (data part) of the cd is homogenious and didn't contain any tracks until it is burned. So I don't see how the "data can be narrower".
The writer makes the data narrower but you have to enable "overburning" in the burn program.Nero was(is?) able to overburn to 99min and so was Fireburner.You can also use 80min CD-R's to burn 780MB by using mode 2.
Originally Posted by jimdagys
http://www.pctechguide.com/33CDR-RW_Disc_capacities.htm
CD-R's have a pre-formed spiral track, with each sector address hard-coded into the media itself.
"Overburning" is not done by making the track narrower, that can't be changed on a CDR blank at all.Originally Posted by MOVIEGEEK
It just burns closer to the outside edge.
http://www.pctechguide.com/33CDR-RW_Overburning.htm
Overburning, also known as oversizing, is basically writing more audio or data to CD than its official capacity by utilising the area reserved for the lead-out and perhaps even a few blocks beyond that.
This article explains the problems with 90/99min CD-R:
http://www.feurio.com/English/faq/fa...99mincdr.shtml
Apart from the track which is inevitably too narrow on 99 minute CD-Rs (And thus the problem that many CD players can't even find the track and thus when playing the CD back may "jump") there are several much more serious problems:Having problems ripping a DVD? Read my guide
I bought "100 min/900 MB" CDRs here, brand was "Sky Pro" if that means anything. Never used them to full capacity, but the CDs I did burn were readable.Originally Posted by MOVIEGEEK
I use the TDK 800BM/90 minute discs quite often. Burn to damn near full and they play in everything I've ever tried them in. LG Burners, Prassi Ones, and oversized media.....can't beat it.
I bought sky pro 99min cdrs that worked great for audio cd and vcd but if you burned them as data cds they would be partially unreadable
Cheapest and Best website to purchase blank cds?
By nadizo in forum MediaReplies: 7Last Post: 31st Aug 2007, 02:25 -
Printable Audio Blank CDs?
By mlong30 in forum MediaReplies: 11Last Post: 16th Jul 2007, 15:33 -
DD0401 can't read blank CDs
By psal2 in forum DVD & Blu-ray WritersReplies: 0Last Post: 5th Jul 2004, 13:59 -
Trouble with Blank CDs *HELP!*
By Infectious in forum Authoring (VCD/SVCD)Replies: 2Last Post: 19th Nov 2001, 04:16 -
my writer writes "blank" cds please help
By roopam77 in forum Authoring (VCD/SVCD)Replies: 11Last Post: 29th Aug 2001, 11:57
