I have a very old external firewire connectable DVD burner with a Pioneer DVR-A03 drive in it.
As replacement drives are pretty cheap these days I purchased an LG GSA-H55N drive to replace the A03.
Swapping the drives was straight forward and simple.
Burning CD-R and DVD-RWs works fine, no problems; however not so with DVD-Rs or DVD+RWs. Either the burn won't start or the burn won't complete after writing the leadout. It just stops.
I put the A03 back in and tested various formats. They all work, except that they write at 1 or 2X of course.
Would I be right in assuming that the firewire to ide interface is simply unable to deal with the later technology of the faster burning drive?
At this point I'm thinking of putting the A03 back in and keeping the LG as a spare for my internal dvd drive. (Been through 3 of them in the last 8 years).
Thoughts/opinions welcome.
I sort of doubt that FireWire is the problem, but anything is possible. Did you set the jumpers on the new drive to Master? I'm assuming a IDE (PATA) drive because you say the box is old. SATA and PATA optical drives operate with a fairly slow data transfer rate, 33 to 66MB's second, if I recall correctly, and that's well within the transfer rate of a FireWire or or a USB interface.
I wonder how many times this has actually happened? I ask because if the sample is small it may not be a media issue but rather a connectivity problem. The cable may be loose or it may be the way the drive is balanced.
If it is a media issue then it might be brand specific and trying another brand might solve the problem.
I don't like to knock any company because of just my own issues which might be explained by other factors but I have 2 LG writer/drives (8x and 16x) and I liked the LG4163b at first but I'm no longer a big fan. In my limited experience I found mine could be finicky with certain media and speeds causing misreads of even perfectly good pressed discs and about 2-5% bad burns (Verbatim 16x) mostly for no apparent reason. I was beginning to think this was a fact of life with faster DVD media. I now have a sata Liteon iHAS120 on my other system it has yet to burn a coaster nor have I found a disc it couldn't read.
I was looking for the same LG you have but they were out of stock and I was offered the Liteon at a similar price. At first, I had my doubts but it's won me over.There's not much to do but then I can't do much anyway.
Thanks for the feedback guys.
I've printed off a copy and will go through it later when I have a chance.
I'll follow up with some more testing and get back to you.
Daisy chain miniDV camera to external firewire drive to PC or ?
By rockitman in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2010, 12:35 -
Raid 1 Firewire external drive, need to use on Mac AND Windows 7
By apollo1980 in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2010, 14:00 -
Problems with DVP5990 and External Hard Drive
By maryp1987 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Apr 2009, 19:28 -
Why won't MiniDV camcorder pass signal through to external firewire drive?
By KeepItSimple in forum MacReplies: 12Last Post: 24th Oct 2008, 07:49 -
Firewire or usb2.0 for external drive media center recording? esata?
By yoda313 in forum Media Center PC / MediaCentersReplies: 29Last Post: 8th Aug 2008, 19:42
Statistics
Newest guides
Latest tool updates
New media comments
