Hi.
I'm having trouble reinstalling the ffmpegX program after I removed it a few days ago. Here are the steps which I took and the result of it. I have a 1.25 GHz PowerPC G4 with Mac OSX 10.5.7, a 74.4 GB HD, and 768 MB of RAM.
*Please note that I'm totally new with video and audio file formats and have no knowledge on coding. When I first installed ffmpegX on the same computer mentioned above, everything went well but not on my second install.
STEP 1: Deleting ffmpegX after 1st time install
I used Apple Cleaner to delete the program. Here are the results on what was removed:
The application "ffmpegX version 0.0.9y" and "all accompanying documents" (ReadMe.rtf, LisezMoi.rtf, Leggimi.rtf, Credits.rtf, ffmpegX manual.webloc) that came with the original ffmpegX.dmg which I downloaded from ffmpegX site. These items where in a folder called ffmpegX in my application folder.
The preference file "com.mac.homepage.major4.ffmpegX.plist"
This came from the ~/Library/Preferences.
A folder called ffmpegX that resided in /Library/Application Support/
The contents were these Unix executable files: mencoder, mpeg2enc, mplayer
I made sure I deleted the files in the trash bin and restarted the computer.
STEP 2: Reinstalled ffmpegX version 0.0.9y
I downloaded a new ffmpegX.dmg file from the ffmpegX site making sure it was version 0.0.9y
When the the disk image was decompressed, I copied its contents (ffmpegX application and accompanying documents) in a new folder called ffmpeg X in my applications folder.
I then went back to the site and read the manual on what else to download. It instructed me to download the binaries mencoder, mplayer, and mpeg2enc.intel (ctrl-clicked the link given) from the links provided. All was downloaded to my desktop.
STEP 3: Finish reinstallation
I doubled clicked on the ffmpegX app and the installer window came up asking me to locate the missing binaries that I downloaded. After indicating the location of these files (in my desktop) using the browse button, I used my login password and pressed install
After waiting for a few minutes a window opened up and gave this message:
The installation was not successful.
##connect to address "IP address 1": Operation timed out
Trying "IP address 2"...
connect to address "IP address 2": Connection refused
connect to address "IP address 1": Connection refused
The lines pertaining to connecting to the 2 addresses above repeated about five times on the same window and allways came with a "Connection refused" result. After that, the ending message on the window is as follows:
/Application/Video.hsd1.state.comcast.net: Operation timed out
tar(child):/Applications/ffmpegX/ffmpegX.app/Contents/Resources/mux.tgz: Cannot open: (null)
tar (child): Error is not recoverable: exiting now
gzip: stdin: unexpected end of file /Applications/ffmpegX/ffmpegX.app/Contents/Resources/gnutar: Child returned status 2
/Applications/ffmpegX/ffmpegX.app/Contents/Resources/gnutar: Error exit delayed from previous errors
What do I do now?
DDiego1000
The installer should not have to connect to any IP address. Trying to connect to an earthlink.net IP (207.69.131.9) is very weird.
/Application/Video.hsd1.state.comcast.net is also unknown to me.
Puzzling...
Edit:
I can think of two things that can cause this.
1/ Another application is sending these connection messages. Is something running in the background?
2/ You downloaded a trojan-infected version. Unlikely (high profile commercial software would be more likely) and never reported (news would have spread), but possible. The file on the official site is the same as I used to install ffmpegX some time ago, with these hash checksums:
SFV (CRC-32): 9A95D47D
MD5: 0aad2e8176798ba677a63097611ffd21
SHA-1: 8ad550c983178b290f4b7b3626133cdd2d24958e
.dmg file size: 33,760,087 bytes
What paint program do you use for your computer?
By johns0 in forum PollsReplies: 26Last Post: 25th Nov 2011, 04:02 -
Help - removing & reinstalling codecs/ filters in Windows 7 64
By JorgeO in forum Newbie / General discussionsReplies: 3Last Post: 19th Sep 2011, 15:52 -
Is any way i can finialize these DVDs with a computer program?
By srhewett in forum DVD RippingReplies: 8Last Post: 14th May 2010, 16:03 -
Removing VirtualDub from Computer
By Sidus1 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 17:04 -
Need a program like FFmpegX for my Windows machine
By johncarlson21 in forum ffmpegX general discussionReplies: 3Last Post: 30th Jun 2008, 23:58
Statistics
Newest guides
Latest tool updates
New media comments
