FFMpegX is working great, but it's a bit of a hassle to manually assign PSP settings, given that it's still using the Firmware circa 1.50 limitations (which were fixed in 3.30 and moreso in 5.0). The PSP can now play video not only in its native resolution (480x720), but at DVD resolution (720x480), which is useful for TV playback (which the 2000 and 3000 models are capable of).
Given how cheap Memory Stick Duo's are, and how easy to is to carry the device around, the PSP makes a remarkably useful video playback device. Is there any chance we'll see updated profiles? If not, is there any way someone could post an easy-to-download, community-made/updated profile?
Thanks for your time (both to other users and, of course, especially the devs)
Thread: PSP profiles woefully behind
I do not have a PSP to test settings myself, but it is quite easy to make your own presets. Set the setting the way you like it/the way it works for you, then save the settings as a preset file (*.ffx) from the File menu.
Next time you need to convert, load your source file, then load the preset from the File menu, Encode.
I do encourage others to share their preset file on the forum here, too.
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 06:00 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13 -
Different Mpeg Profiles
By AndreL in forum EditingReplies: 2Last Post: 11th Jun 2007, 10:00
Statistics
Newest guides
Latest tool updates
New media comments
