Some videocams and digicams shoot AVCHD or MP4 video in 1280x720 at 60p. The format now appears in both high and low end devices. Information about its applications is, however, scant.
Do any software packages burn BD or AVCHD-DVD discs based on 60p video without downscaling or lossy recoding?
Will most, or perhaps only a few, dedicated BD players play such discs?
Thanks for any advice.
multiavchd (simple menus), tsmuxer (no menus) to author, imgburn to burn. All free, no re-encoding and allow pass through of compliant streams (i.e. you can take it straight from your camera to disc)
DVD Architect 5+, Encore CS4 will allow pass through of compliant streams as well, and have more capabilities if you want a full authoring suite, but Encore CS won't allow AVCHD on DVD5/9 media, only true Blu-ray BD25 media
The majority of standalone players will play these discs, either BD5/9 , BD25, but the settings are different if you use true blu-ray disc vs. DVD media vs. SDHC card (folder structure is a bit different), and you just use the labelled option. Each player may have quirks or idiosyncracies, and may need certain firmware revisions to work, but the majority seem to work out of the box. There is a database on Doom9 forums of specific players and notes/workarounds on the specific model.
Of course Premiere Pro, FCP and Vegas Pro all handle 1280x720p/59.94 source and projects and can also do 1920x1080p /59.94 projects. Blu-Ray players currently won't handle 1920x1080p/59.94 so one would export to 1920x1080i.
http://www.kiva.org/about
1280 x 720\60p is not a problem, I do a lot of that myself with my processed HDV footage. MultiAVCHD will even let you create a disk with multiple tittles of various framerates and resolutions. I once made a dvd5 disk as a test with:
1280 x 720 \ 23.976p
1280 x 720 \ 30p
1280 x 720 \ 59.94p
1920 x 1080 \ 23.976p
1920 x 1080 \ 30p
1920 x 1080 \ 60i
1920 x 1080 \ 59.94p
Everything played perfectly on my Panasonic BD-35 player except the 1920 x 1080 \ 59.94p. In that case, only the audio played and not the video.There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
So MultiAVCHD will create disc images or burn them too? Will the resulting discs play 1280x702 60p video on a any dedicated BD player that accepts BD-RE?
Since MutliAVCHD does not recode, are the system requirements also fairly simple? My system is only 2.4 ghz core 2 duo.
If one works with Vegas Pro, does it take more CPU and graphics power to edit 1280x720 60p than for AVCHD at 1440x1080i?
I read someplace that Premier Elements 7 has trouble with 60p (stutters, missed frames) and that Pemier Pro hangs on AVCHD. Is this mistaken?
Might MultiAVCHD function more or less the same as the ArcSoft Media Impression bundled with Kodak pocket cams that shoot in 1280x720 60p?
Finally, once one creates a BDMV folder, does it matter whether one burns it to a BD disc or a simple 4.7 GB DVD+R? Wouldn't either play the same on a BD player?
It is recommended to use imgburn to burn (UDF 2.5)
720p60 should play in all BD Players that accept that format or have "AVCHD" label, but beware some are "picky" and some require certain firmware revisions to work properly. You should search the various forums for specific info on your model (you can also try Doom9 forums, AVSforums)
Your system is fine for MultiAVCHD, but editing might be difficult/sluggish
I don't know about Elements, but Premiere Pro CS4 works fine with AVCHD
You can use either DVD or BD media, but the folder structure is slightly different (if you use multiavchd, the options are labelled, if you use tsmuxer, use "avchd" for DVD media, "blu-ray" for blu-ray media)
About the same number of pixels being processed per second. The issue is AVCHD compression.Originally Posted by PersistenceRecommends: Kiva.org - Loans that change lives.
Blu-Ray 60P
By pepegot1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2012, 11:49 -
can you make a blu ray that is is 60p?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD)Replies: 23Last Post: 12th Jan 2011, 01:38 -
blu-ray and vc-1 specs for 1280x720?
By wiseant in forum Authoring (Blu-ray)Replies: 1Last Post: 2nd Jul 2010, 22:52 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
