Hi there,
It seems like the whole world wants to go from m2ts to something else alas I want to go the other way.
Recently I purchased a Panasonic g10 plasma TV, it has the ability to play m2ts files in the exact format used by AVCHD SD writing camcorders.
Though I have found software to go from m2ts to other formats I have found nothing that creates the m2ts files and the specific file structure needed for the camcorder or the TV to play.
For the record I do not have a camcorder so I cannot even get the specific file format.
Anyone solved this problem?
Anyone know a way to solve this problem?
Steven
I would try AVCHDCoder or D2MP, they convert directly to AVHCD.
Or use handbrake, xvid4psp and convert to h264 video with dolby audio in a mkv. Then use multiAVCHD to make an AVHCD from the mkv. Be sure to stay within the blu-ray/avhcd standard, www.videohelp.com/bd#tech
The folder structure required is different for Panasonic Viera , than regular AVCHD on DVD5/9, but multiavchd has that option for SDHC
http://forum.doom9.org/showthread.php?t=143744
http://multiavchd.deanbg.com/tutorial.php
EDIT: oops I see baldrick beat me
Super
going to go and try that out
Would be nice to be able to use the SD slot
Thanks muchly
Cheers
Steven
Not working alas.
Set the res to 1080i and refresh to 25 as per the guide but tv still does not recognize the movies
Any more suggestions?
Steven
Please check out this thread, it's dedicated to multiavchd and Viera TV's
http://forum.doom9.org/showthread.php?t=146602
Also, check your multiavchd version. There is usually a new version every few days with very active development. IIRC, the last version broke a lot of things. You can talk directly to Dean or other users that have your same setup at Doom9
Oh sorry about that, I will move over to the correct thread.
Steven
I need the file structure of MPEG-4 AVC video
By ahrouhi in forum Video StreamingReplies: 6Last Post: 18th Mar 2011, 00:05 -
Sony/Panasonic m2ts file date correction
By renzo2000 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 25th Aug 2010, 16:07 -
Any good utility to join m2ts (or MTS) from AVCHD camcorders?
By sebaz in forum EditingReplies: 4Last Post: 17th Jan 2010, 11:10 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14 -
Creating a blu-ray disc from .m2ts and .srt file
By denada in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Aug 2009, 14:29
