hello everyone,
i hope it's alright to ask such a question here since my problem involves video and audio issues with my home theater system.
i have a SONY Bravia LCD with HDMI port,Sony DVD Home Theatre System - DAV-DZ777 and Sony Playstation 3...
here's the specs for the home theatre system..i only copied the important details regarding the audio...
AMPLIFIER
S-Master
Yes
Audio Line IN/OUT (Analogue)
2 / –
Audio Line IN/OUT (Optical)-------is this where i buy optical cables?
1 / –
Audio Line IN/OUT (Coaxial)
1 / –
Audio Input (Front, mini)
1
Video Signal IN/OUT (Composite)
– / 1
Video Signal IN/OUT (Component)
– / 1
Video Signal OUT (HDMI)-------there is only one HDMI port at the back.(.output)
Yes (1080p)
USB
1
Headphone Jack (3.5mm / 6.3 mm)
3.5 mm
D.C.A.C (Auto Calibration)
Yes
Bass Boost Function (Dynamic Bass on RM)
Yes
Night Mode (Normal/Plus)
Normal
Portable Audio Enhancer
Normal
Dolby Pro Logic/Dolby Pro Logic II
– / Yes
Dolby Digital
Yes
DTS
Yes
Multi Stereo (Link)
Yes
A/V Sync (Lip Sync)
Yes
Speaker Formation
Yes (low)
Timer (REC/PLAY/SLEEP)
Yes (– / – / Yes)
S-AIR Ready
Yes
BRAVIA Sync
Yes
DIGITAL MEDIA PORT
my question is,i want to connect my ps3 to my LCD TV and i want the sound to come out through the home theater system,not the television internal speakers.how do i do that?what cables should i buy?? someone said i should get optical cables..are they same like HDMI cables??? any suggestions would greatly be appreciated..thanks in advance..
Thread: PS3 to Home Theatre System
HDMI carries both video and audio, so that should be the connection of choice, except that your amplifier, as an all-in-one unit, has no HDMI in. This means you are limited to component in if you want to run the video and audio through the amplifier. You can use the optical out on the PS3, however you are limited to a 5.1 downmix instead of True-HD if you do this.
I have my PS3 hooked up via HDMI direct to the TV (my amplifier has no HDMI - too old) and optical to the amplifier for audio. Note also, on the PS3 audio is HDMI or optical, not both. If you hook up an optical connection the audio is not sent through the HDMI cable. In your case I would connect the PS3 directly to the TV using HDMI, and the audio to the amplifier using optical.
thank you so much gun1inger!!!..your answer was what i was desperately looking for
well,just to be sure,optical digital cable looks something like this right?
blu ray to ps3 for home theatre center
By jmaverick101 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 13:30 -
ps3 linked to home theatre
By ordinaryguyukuk in forum DVB / HDTVReplies: 2Last Post: 9th Jul 2009, 00:48 -
Sony DAV-IS10 home theatre system
By joemarsh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Jan 2009, 13:07 -
Samsung HT-TX715T Home Theatre System
By Heatseeker79 in forum AudioReplies: 0Last Post: 3rd Nov 2008, 06:55 -
Home theatre system that can't play Divx
By mr-scarface in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th Jun 2008, 13:19
Statistics
Newest guides
Latest tool updates
New media comments
