When I hook up my HDMI cable I get a msg that says "DVI alert: Your HDTV doesn't support HDCP. Disconnect the HDMI cable and connect using component cables." I've heard that the pic is better with the HDMI so that's what I want to use. Is there a menu or something that I need to access so that I can use the cable? I've called the Vizio and my cable company, both point fingers at each other as the problem. I tend to think it's a cable box issue not really a tv issue but I'd sure apprecieate some help here. And, just to complicate matters a bit more, I'm planning on adding a Blu-Ray player, does anyone know if it'll have an effect on this problem? Thx in advance
Results 1 to 12 of 12
The box is saying the HDTV HDMI input isn't HDCP compliant. Try it on another HDTV or on a HDCP compliant computer monitor (HDMI->DVI-D).Originally Posted by aimee43
Otherwise use analog component.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I get the same msg on another TV, that leads me to beleive it's an issue with the digital cable box but does that mean my only option is to use componenet cables? Seems like a crummy aleternative since the HDMI pic was significantly better when I viewed it in the store.
Not that much better. What is the model of your HDTV?Originally Posted by aimee43
You can exchange 8500HD units but you will lose all stored files.Recommends: Kiva.org - Loans that change lives.
Vizio SV470XVT FHDTV
What do you mean "You can exchange 8500HD units but you will lose all stored files. "
That TV should work. Demand a no charge service call.Originally Posted by aimee43
If you exchange the 8300HD, you will lose your stored files.Recommends: Kiva.org - Loans that change lives.
I've already called for a svc call, they'll be out this Friday. I'm afraid I'm going to hear the same old thing "we don't support HDMI, you're on your own" I've asked them to bring a newer DVR, we'll see. Thx for your help
Did they tell you they don't support HDMI? You didn't say that.
That is entirely their choice. They program the box and can block HDMI if they want.
I've never seen a cable company do this since HDMI+HDCP protects them.Recommends: Kiva.org - Loans that change lives.
It supports HDMI but you'll have to go through the remote control of the digital box to set it. I can't remember what setting it was but you do have to go through that setup. Do a search on google or AVS Forums. Time Warner doesn't support HDMI on their HD boxes but you can use it.
I returned a digital HD box because too many issues using HDMI when you wanna record on vhs. Yuh, my folks still use a vhs and record stuff so I ended up returning their hd box. I returned my hd box because I record stuff from my dvd recorder. I use HDMI strictly for my Panasonic Blu-ray player and upconverting Sony dvd player.
The cable co said "we supply the connection but we don't support HDMI" . Everyone seems to be taking this pretty well from what I've read but I'm not sure why. You pay extra for HDMI, it's on nearly every new TV you buy yet the two cable co's in my area don't support it. I would think people would be screaming about this but it seems everyone is saying, just use the componenet cables. I've got the cable co coming out tomorrow to give me the most current box they've got and I'll see if that makes a difference but I'm betting it won't. Do you know if the Blu-Ray that I'll be adding will cause problems?
You should have no problems with using a Blu-ray player. The problem you're having with the digital cable box and HDMI has nothing to do with using a Blu-ray player.
You would just connect the cable box YPbPr and the Blu-Ray player HDMI.
scientific atlanta cable box explorer 2000
By Darkcast in forum DVB / HDTVReplies: 1Last Post: 13th Mar 2011, 13:49 -
Scientifc Atlanta 3250HD cable box questions
By joecass in forum Newbie / General discussionsReplies: 23Last Post: 27th Apr 2010, 14:31 -
scintific atlanta 2200 cable box
By bammthis in forum CapturingReplies: 8Last Post: 16th Mar 2010, 00:32 -
Scientific Atlanta HD Cable Box / HDMI Audio Problem
By culttvguy in forum DVB / HDTVReplies: 5Last Post: 14th Sep 2008, 15:48 -
Scientific Atlanta 8300 HD/PVR Rogers Cable Recoding Required To Work.
By musicmavern in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Aug 2008, 11:52
