VideoHelp.com Forum
    Hi all
    My HTPC is running Vista ultimate on D945GNT intel board with Pentium D 3.0 GHz and 2G ram.
    I recently purchased PointOfView nvidia 9500GT graphic card with HDMI,
    I am able to see VGA output through My HDReady plasma screen, but I am unable to see output through the hdmi port, I tried everything downloaded beta nvidia drivers, read endless posts regarding hdmi problems but i was unable to find a solution.
    today i took the HTPC to a lab and the technician suggested that the mobo is the problem
    Is there any known issue with 945 and hdmi?
    Thank you!!
  2. DVD Ninja budz's Avatar
    I'm assuming you're using a DVI to HDMI cable. Or are you using a HDMI to HDMI cable? Have you tried turning on your pc then plugging in the HDMI cable from there to your plasma TV? Then turn the plasma tv power on. That method would be if you're using a DVI to HDMI cable.
  3. Member edDV's Avatar
    If that doesn't work, I've found the opposite works for me. Turn computer off and TV on set to HDMI in and connect cables. Then boot the computer. My 9600GT then finds the TV. My mobo is a Gigabyte with 945 chipset.
    http://www.kiva.org/about
    I tried both DVI<->HDMI (usind DVI->HDMI adapter) and HDMI<-> HDMI,
    I tried to turn computer and TV off then boot the PC with HDMI connected, didn't help...
  5. your plasma TV?
    Some Gfx card + some Tv incompatible .. SAmSung? Sony
    define Lab & Technician
    The electronic components of the power part adopted a lot of Rubycons.
    Originally Posted by RabidDog
    your plasma TV?
    GFX card = Point Of View Nvidia chipset 9500GT with HDMI output port
    Plasma Tv = fujicom PP-42G23H
    http://www.fujicom.com/web/Catalog.a...&ProductId=636
    I am not sure whether it’s PAL/NTSC or multi system
    Lab & Technician = local computer store with computer technician (someone with same or less knowledge then me, that gat paid to solve problems I can solve on Google )
    Just a quick update...
    The Mobo was replaced by a new Gigabyte one (S somthing)
    Now the HDMI output is working like a charm...
  8. DVD Ninja budz's Avatar
    Good to hear it's all solved! Gigabyte rules!
  1. HTPC problems with HDMI audio
    By moviewatcher666 in forum Media Center PC / MediaCenters
    Last Post: 9th Feb 2011, 11:51
  2. Bitstream problem on INtel DH57JG via HDMI
    By cjbrown80 in forum Software Playing
    Last Post: 12th Sep 2010, 20:25
  3. Replies: 33
    Last Post: 12th Mar 2009, 00:19
  4. Likely problems upgrading motherboard from sis650 to sis651 chipset
    By blinky88 in forum Newbie / General discussions
    Last Post: 11th Aug 2008, 14:34
  5. Vista and intel AHCI disk controller problems.
    By ofbarea in forum Computer
    Last Post: 20th Nov 2007, 20:36
