Ok, now that I have this technique working, can anyone tell me if this will work with 3D movies if I'm doing a 1:1 copy to a BD50, as up to step 4 in the guide?
I want to copy Avatar 3D but I'm not going to spend the money on a BD50 disk if I'm just wasting my time with it.
Results 211 to 215 of 215
Ok, well to answer my own question yes, the first step does a perfect 3d 1:1 copy onto a 50gig disk!
OK, everything went fine up to the point I had to drag and drop the index.bdmv file to the patcher. I get an error stating "This file is not correct format". I'm using all the latest versions of the essential files. Should I try downloading the same files originally used or could I have done something else wrong?
OK. My bad. I finally took my own advice and read ALL the posts and found another reference to my problem. I'll start trying some of the workarounds.
Thanks for this thread. It's great.
Thanks alot for the guide first off. I was wondering if there was any way to make BD Rebuilder utilize more of my processor in order to complete the encoding more quickly. I have it set to high priority currently but it is only utilizing 40-50% of my processor.
Blu Ray Burner or SD card for backups
By bz186 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Mar 2011, 09:57 -
My DVD backups are "invalid" in Sony Blu ray player
By KeithMckane in forum Authoring (DVD)Replies: 6Last Post: 26th Feb 2010, 15:11 -
Making DVDs from backups of VOB files
By kirklt in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 08:52 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 02:00 -
What do I need to do for making backups to play on PS3(japan)
By korazy in forum DVD RippingReplies: 4Last Post: 27th Dec 2008, 13:50
