VideoHelp.com Forum
  1. Ive been using AutoGK for my DVD backups but I'm not contented with its quality. I tried converting my own DVDs using VirtualDubMod with Standalone compatibility (No Custom matrix (AutoGK uses Custom Matrix and its incompatible with standalone players), No QPel, No GMC, VBR 2-pass) - based from http://www.divx-digest.com/articles/...tup_page1.html. I want to use XVID in Codec ID. I adjust my bitrate to 800kbps to compare AutoGK' quality, my own and my other video downloaded from the internet. This is my video's MediaInfo:
    Video
    Format : MPEG-4 Visual
    Format profile : Streaming Video@L1
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 36mn
    Bit rate : 825 Kbps
    Width : 640 pixels
    Height : 352 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.162
    Stream size : 222 MiB (86%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    The video that I downloaded surpasses AutoGK's quality, consequently the video I personally converted didn't even exceeded AutoGK's quality. It has very poor quality and its very blocky while the video I downloaded has crisp and very high quality with the est. same bitrate (800kbps).Where do I start modifying Xvid Settings to surpass AutoGk's quality?
    Every video is different. No single bitrate is going to be good for all videos:
    The higher the resolution -- the more bitrate you need.
    The more detail in each frame -- the more bitrate you need.
    The more the picture changes from frame to to frame -- the more bitrate you need.
    The more noise in the video -- the more bitrate you need (same as previous two, really)
    The higher the frame rate -- the more the bitrate you need.
    The higher the contrast -- the more the bitrate you need.
    AutoGK examines the video and sizes the frame (smaller frame = lower bitrate required) in order to get some kind of balance between resolution and macroblock artifacts. Of course, resolution is a part of quality, otherwise we'd all reduce all our videos to a 1x1 pixel frame size and store them uncompressed. So what AutoGK is really doing is trading one type of quality for another.
    Why do you need some arbirtrary bitrate? Just use Target Quantizer encoding. Pick the quality (quantizer) you want and every frame comes out that quality. The file turns out whatever size is necessary. Be sure to use a version of Xvid with Adaptive Quantization.
  3. Originally Posted by helloworld123
    Maybe if you had bothered to read the included tutorial you'd have seen that by installing it with the ESS chipset option, or by turning it on in the Hidden Options, you'd get the standard matrices and other features that ensure full standalone compatibility.
    And as mentioned, unless you're comparing the encodes of the same movie, then your comments about the relative merits of the different encoding methods and the AVIs they produce are useless and pointless. That said, if you knew what you were doing you could do a better job than does AutoGK. But you don't, so you can't.
    Is it possible, for a particular size target, i.e. 1cd, 1/4 dvd or 1/3 dvd to estimate manually this balance? (would there be a way to log AutoGK's analysis before encoding?)
    Would the Quality Factor be a reasonable indicator? (and some people suggest aiming at .2 bpf minimum)
    Look at the videos on this post and decide for yourself if QF is a good measure:
    http://forum.videohelp.com/threads/2...=1#post1811057
  1. Simple CROP of AVI (XVID) in virtualdubmod
    By Rudyard in forum Editing
    Last Post: 1st Jun 2010, 20:43
  2. Replies: 9
    Last Post: 20th Jan 2009, 07:44
  3. Virtualdubmod Interleaving settings
    By dvdfreak1971 in forum Audio
    Last Post: 29th Apr 2008, 09:55
  4. MPEG2 to Xvid with Virtualdubmod
    By Cazz in forum Editing
    Last Post: 26th Feb 2008, 13:49
  5. Replies: 2
    Last Post: 14th Jan 2008, 03:56
