Hi everyone I really am not that familiar with a bunch of this computer stuff. What I am trying to do is connect my laptop computer to an external monitor.
Ok so my setup is this:
I have a Dell Latitude D820. It has vga output only.
My monitor has svideo, component, and hd component.
There are cables that connect vga to svideo but I found they do not work for most newer computers. Also there are vga to dvi converters and then dvi to hd cables I could use, but this would be upwards 200 dolla. I figured a new video card with some new ports would be the better option.
What I am looking for is something like this: http://www.newegg.com/Product/Produc...82E16814127301 but specifically my computer.
Can you help me find a video card that will be an improvement from the one already on my computer, but also has each of these three ports(dvi, svideo, and hdmi,,,I heard you could get cards that have a dvi port only for like 50 bucks!)??
Thanks a lot
Results 1 to 11 of 11
Thread: Looking for a certain video card
You have a laptop so you can't change your videocard,you have to buy a VGA to S-Video converter:
http://sewelldirect.com/PC-to-TV-Converter.asp
O wow. Are you sure that converter will work for my laptop. Like can it my video card output that. I thought laptop vga was a little different.
like why would this work and a vga to svideo cable not work
The S-Video quality from a converter will be poor.
You either need to change your laptop to one with analog component out or change your TV for one with VGA in.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
VGA is RGB+HV sync. S Video is Y/C NTSC.Originally Posted by thejollypostman
Like the difference between a forklift and a lawn mower.Recommends: Kiva.org - Loans that change lives.
According to http://www.notebookforums.com/thread187620.html you could also use a DPort Port Replicator, or the Dell D/Dock Expansion Docking Station for TV-out. Not inexpensive though.
how poor quality are we talking about edDV. i dont need that good quality actually. Just would it work ?
About 640x480 but less sharp for text. OK for video playback.Originally Posted by thejollypostmanRecommends: Kiva.org - Loans that change lives.
Ok well thanks a lot I think il go with the converter . This resolution would be fine for my application.
But one more thing,, does the converter take care of the VGA is RGB+HV sync. S Video is Y/C NTSC problem??
Yes, it is a scan converter with Y/C out.Originally Posted by thejollypostmanRecommends: Kiva.org - Loans that change lives.
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 02:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum CapturingReplies: 6Last Post: 26th May 2011, 13:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum CapturingReplies: 3Last Post: 15th Sep 2008, 02:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum CapturingReplies: 14Last Post: 18th Jan 2008, 21:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum CapturingReplies: 1Last Post: 6th May 2007, 17:15
