I am trying to convert output from Canon Vixia HF100 to Blu-Ray formatted dvd using Sony Vegas Movie Studio Platinum 9. When I do this the video is excellent but after a few seconds the sound begins to stutter. When the video is turned off (oppo BDP83) the sound is excellent. When I pause playback and restart the disc video and sound are in sync for a few seconds then the stuttering begins again.
Any suggestions on how to fix this? Sony help has not been helpful.
Moving you to our blu-ray authoring section as you are making a blu-ray/avchd...on a dvdr then.
How does it work on your computer using a software blu-ray player?
What audio format are you using?
If you are playing a 1080p m2ts file then its your computer thats too slow if its the xp2400 as described.
Ben Johnson-I didnt take any stereos!
Sorry old Profile has been updated. Don't have software to play bluray on computer; using ac3 audio. Vegas gives excellent results once you figure out how to use it but is very user unfriendly - or, I'm just really stupid.
Any reason you need to convert with Sony Vegas Movie Studio Platinum 9?Just copy the file and load it straight into tsmuxer,no need to convert.You dont need blu-ray software to play m2ts files,just codecs which are free.
m2ts to Blu-Ray and DVD format
By doruforum in forum Video ConversionReplies: 10Last Post: 19th Sep 2011, 11:31 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 22:04 -
Any other than Blu-ray DVD player in the market supporting AVCHD format?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Aug 2010, 11:41 -
Convert MTS files to DVD or BLU RAY format
By flix in forum Video ConversionReplies: 4Last Post: 21st Apr 2010, 21:03 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
