Hi,
I want to buy a Blackmagic Intensity (maybe pro if I really need it) so I can record my Xbox. I also want to hook up my xbox to my computer moniter (Acer AL2216w which has a DVI-D and VGA input) but I don't want to buy it unless I'm sure I can use it. How will I set it up? Can I use an DVI-D/HDMI splitter and connect the HDMI to the BM and then the DVI-D into my moniter? And also, I have external speakers because my acer moniter doesn't have built in speakers, how will I be able to set that up so it plays audio from my xbox?
Sorry if this is already posted somewhere I'm new and too lazy to look.
Thanks in advance
EDIT: Ok I think I have it figured out, but another question: If I plug in the XBOX 360 VGA adpter, will I be able to plug in the HDMI to the BM? Or will the XBOX only work with one thing plugged in.
Results 1 to 1 of 1
Thread: XBOX 360 Blackmagic Intensity
blackmagic intensity pro xbox 360 help
By tehshame in forum CapturingReplies: 11Last Post: 18th Nov 2010, 14:24 -
Help capturing from Xbox 360 with Blackmagic Intensity Pro
By SkinnyRabbit in forum CapturingReplies: 10Last Post: 1st Oct 2010, 09:44 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum CapturingReplies: 6Last Post: 15th May 2009, 16:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum CapturingReplies: 0Last Post: 22nd Apr 2009, 14:27 -
blackmagic intensity / Xbox 360 / Adobe premiere pro CS 3
By jonakangou in forum CapturingReplies: 11Last Post: 16th Jul 2008, 23:42
