Is last years model better? (HF11)
Going by the reviews the HF200 does bad in low light other than that what is the differance in the HF11 and HF200? I see none but the 15x Optical zoom on this years model.
Thoughts?
Thread: Canon HF11 or HF200?
Since I had to make the same decision, let me help you out: main differences between the two are (in favor of the HF20): 24mbps recording, face recognition, 15x zoom, Digic III processor, pre-record, higher mp pictures, new UI, supposedly better buttons and (especially kept this for last) smaller sensor with higher megapixel count.
Now, I have the HF200 because I figured I'd do most shooting outdoors/in good light anyway. When this is the case, the HF200 simply trashes the HF10 (HF11 has 24mbps too), it provides a lot more resolution. But when lights dim, the HF200 does struggle a bit with noise, so cinema mode/25P is needed to get a better picture in those cases.
Livestreaming from Canon Vivia HF11 ?
By King Din in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 7th Mar 2011, 10:18 -
Canon Vixia HF11 Inputs?
By markypizz in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 2nd Aug 2010, 22:43 -
Canon HF11 converting video footage problems
By AP joe in forum Camcorders (DV/HDV/AVCHD)Replies: 25Last Post: 4th Apr 2009, 20:30 -
Editing Canon HF11 30p/24Mbps AVCHD footage With VideoStudio 11.5+ HELP!
By tat2jr1 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 11:25 -
Canon HD Vixia HF11 - problem burning to DVD [Solved]
By Jeremiah58 in forum Camcorders (DV/HDV/AVCHD)Replies: 20Last Post: 24th Sep 2008, 09:37
Statistics
Newest guides
Latest tool updates
New media comments
