VideoHelp.com Forum
  1. Hi everyone
    I am having issue export to format h264 specify but my client they want for tv broadcast
    these are the specs,
    I did quicktime convertion usung mpeg4 with h264. I have tried and found nothing that can give me the setting ask can any one help.
    I am using a mac pro 8process xeon with final cut studio 2
    Encoding Type: CBR
    Aspect Ratio: 1.33 (4:3). If higher, then letterboxed within a 4:3 frame.
    Video Multiplex: One Video Stream per file
    Video Format: 4:2:0 MP@L3, 525i
    Frame Rate (Video Source): 29.97 fps
    Frame Rate (Film Source): 23.98 fps
    Bit Rate (Video): Max to fill TS – see Transport Stream bitrate spec (below)
    Resolution: 720 x 480 – preferred, if can be supported without significant artifacts being introduced. Horizontal resolutions lower than 720 will be considered if they result in improved picture quality and fewer noticeable encoding artifacts.
    Encoding: MPEG4 Part 10 / AVC / H.264
    GOP (group of Pictures)
    Structure: IBBBP – Preferred, if Hierarchical B encoding is supported.
    If not, then IBBP.
    PES Headers: 1 per Frame
    Length 36 (IBBBP); 45 (IBBP)
    Audio
    Sampling Frequency: 48 KHz
    Supported Format: AC-3
    Audio Mode and Bit Rate: If Stereo source, then stereo (2/0) mode and 192Kbps;
    If multichannel source, then 5.1 (3/2LFE) mode and 384Kbps
    Closed Captioning: EIA-608
    Transport Stream
    Contents: Video, Audio, PSI muxed
    Type: MPEG2 TS
    Packet Size: 188 byte
    Bit Rate: 2.5 Mbps (max), CBR
    PSI Contents: Program Association Table, Program Map Table
    PSI Frequency: 125 ms recommended (250 ms max)
    PCR Accuracy: 27 Mhz (+/- 5 ppm)
    PIDs
    Video stream PID: PID 49 [0x0031]
    Audio stream PID: PID 52 [0x0034]
    Audio 2 stream PID: PID 483 [0x01E3] (optional)
    Audio 3 stream PID: PID 484 [0x01E4] (optional)
    PAT PID: PID 0 [0x0000]
    PMT PID: PID 42 [0x002A]
    PCR: PID 49 [0x0031]
    PMT Identification (video): stream_type=27 [0x1B] (H.264)
    PMT Identification (audio): stream_type=129 [0x81] (AC-3)
  2. Member edDV's Avatar
    H.264 is seldom used as a source broadcast format. Make sure the client specifies exactly what he needs.
    More often they want a tape format or a video server injest format (usually uncompressed or MPeg2).
    The spec above resembles an uplink format rather than a studio or master control format.
    http://www.kiva.org/about
  1. Best Export Method for FCP?
    By Jeff_NJ in forum Mac
    Last Post: 4th Nov 2011, 12:12
  2. BROADCAST EXPORT in Premiere/After Effects
    By elmuz in forum Editing
    Last Post: 26th Apr 2010, 14:08
  3. Replies: 1
    Last Post: 24th Oct 2008, 11:45
  4. Replies: 1
    Last Post: 4th Dec 2007, 18:13
  5. Export to FCP Quicktime Movie
    By James in HD in forum Mac
    Last Post: 2nd Dec 2007, 08:43
