VideoHelp.com Forum
Results 1 to 11 of 11
    Hello everyone,
    I am using Windows Media Encoder (high quality mode) to record screen, but the recorded video quality is not very good. Any ideas how to improve it? Is there any ways to improve video quality by editing profile to apply some magic parameters?
    My environment: Windows Vista + Windows Media Encoder 9.
    Here is the original desktop screen snapshot,
    http://i40.tinypic.com/zmxm6b.jpg
    Here is the recorded desktop screen snapshot,
    http://i42.tinypic.com/9ia5mx.jpg
    thanks in advance,
    George
    That sort of banding would suggest you have your colour depth set too low. Make sure the colour depth is set to at least 16 bit, if not 24 bit. Although this will require a higher bitrate
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Thanks guns1inger, you mean the color depth of my screen resolution or some recorder setting? My screen is already set to be 32-bit.
  4. Click on Properties -> Compression and select Full screen video , but best for screen capture use Camtasia 30 day trial
    Select "select Full screen video", then??
  6. Click Start Encoding
    Another route is Jing > www.jingproject.com, payed version offers other features but free lets you decide.
    What is the required outcome of this project ???
  8. Always Watching guns1inger's Avatar
    I suspect it is related to this : http://forum.videohelp.com/topic368214.html
  9. Member Safesurfer's Avatar
    Have a read of this "Best Practices for using the Windows Media Screen Codec", this part is interesting.
    Should I Use Version 7 or Version 9 of the Windows Media Screen Codec?
    In most scenarios, it is recommended that you use the Windows Media Video 9 Screen codec, which provides improved handling of shaded images, screen motion, and scrolling for screen captures. This latest version supports one-pass constant bit rate (CBR) and variable bit rate (VBR) encoding with no dropped frames, and is fully optimized for both streaming and download-and-play scenarios. It provides a higher frame rate than the Windows Media Screen 7 codec, so users will have a better experience when they view the content.
    Use version 7 when you want all of the capture area, including the continuous-tone regions, to look exactly like the original. The tradeoff of having this exactness is that many more frames will be dropped, and some scene changes may be missed entirely when you capture content using version 7 of the codec. Version 9 decreases the resolution in continuous-tone regions, but provides a better viewing experience. By design, the more restricted the bit rate is, the more quality will be lost in the continuous-tone regions.
    They also recommend not using a Background desktop image, which makes sense.
    http://www.microsoft.com/windows/win...reenCodec.aspx
    This link also has some helpful info.
    http://www.microsoft.com/windows/win...screencap.aspx
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  10. Member Safesurfer's Avatar
    You might also try changing the pixel format to YUY2 per this link -
    http://www.screencapturenews.com/200...media-encoder/
    My video has both high frame rate and bandwidth settings, but is still not of sufficient quality.
    You might have to modify the video processing options. Stop your recording and click on the “Properties” button that is located at the top of the main WM Encoder window. From there, navigate over to the “Processing” tab and select “YUY2" as the pixel format.
    Cool, your solution works! I met with a new issue related to this question, I posted here,
    http://forum.videohelp.com/topic368382.html#1970073
    appreciated if you could take a look.
  1. Improve video quality [HELP]
    By v1rto in forum Newbie / General discussions
    Last Post: 13th Jul 2011, 08:46
  2. What can I do to improve my quality?
    By Captain Satellite in forum Restoration
    Last Post: 27th May 2009, 11:06
  3. how to improve video quality?
    By George2 in forum Programming
    Last Post: 19th May 2009, 02:07
  4. Replies: 4
    Last Post: 29th Dec 2008, 13:38
  5. Replies: 4
    Last Post: 7th Jul 2008, 15:16
