VideoHelp.com Forum
  1. I have som mkv-files that I play on my WD TV-box. Because the WD TV have som synq problems with external subtitles, I want to merge the srts into the mkv.
    From another topic in this forum, someone recommended mkvmerge. I went on adding the subtitle to one of my movies. The filesize was about 8 GB. The process went so fast, so I guess the file could not have been reencoded. But anyway, the new mkv file I got, was som MBs less than the origianal. I don't understand how it could be smaller, because i added the sub, so I thought the new file should be a little bit larger than the original.
    So I want to be sure there will not be any loss in quality using mkvmerge before I start working with my other mkvs. And how could the new file be smaller than the original after adding a srt?
    Thank you very much in advance
    Nope, you wont lose any quality using mkvmerge. But check so it's the entire video so it hasn't cut it at the end.
  1. Does mkvmerge reduce quality when removing subtitles?
    By Moth Queen in forum Newbie / General discussions
    Last Post: 25th Feb 2011, 22:06
  2. Encoder with no quality loss
    By JamesDV in forum Mac
    Last Post: 8th Apr 2009, 11:01
  3. DVD to AVI - without quality loss?
    By maxamillion in forum DVD Ripping
    Last Post: 16th Dec 2008, 16:25
  4. video quality loss
    By majax79 in forum Video Conversion
    Last Post: 24th May 2008, 01:03
  5. Quality-loss due to transcoder?
    By joelson in forum Capturing
    Last Post: 24th Jul 2007, 15:28
