I'm trying to change the region code on this DVD player from 1 to 2. I was able to theoretically change it with the remote's set-up button and the code 741130 (and I selected "all regions"), but even after turning the machine on and off, my region 2 DVDs are still not payable. Am I overlooking something?
I also tried the two other region code hacks listed for this model, and I didn't have much luck with them either. Any ideas?
DVD model: NAD T562
-FranSF
Unfortunately some DVD players cannot be made region free at all. Also, manufacturers may make hardware changes during production that break hacks that used to work. Or hacks may work ONLY on the models sold outside of the USA and Canada, with models in those 2 countries being different in hardware and unhackable.
It is not normally a requirement to turn a player off after changing the region setting, so perhaps you can try the code again and then not turn it off and see if that works any better, but it could also be any of the things I listed previously and you are out of luck.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Need help please changing region codes on my dvd
By ets1012 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2010, 21:55 -
Recording DVD when changing Region Codes
By Sky711 in forum MacReplies: 6Last Post: 18th Aug 2009, 23:49 -
region free codes for sony dvd player
By andy7133 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Apr 2009, 08:58 -
Dodge/Chrysler DVD Player - any hacks for region codes?
By paulfnyc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Nov 2007, 09:35
Statistics
Newest guides
Latest tool updates
New media comments
