  1. I have a DVD movie that was made at work that I need to rip and convert to WMV so that the clips can be hosted on our servers for viewing. I did not author the DVD and we no longer have the original video.
    When I try to rip the video with DVD Shrink, I can see a few of the clips as the main movie, but 90% is listed as "unreferenced material". There is no way to select just that video as the new main movie. If I try to rip with DVDFab, to shows larger video clips to select but when I preview it, it jumps from scene to scene and not the flow that I need to rip nor how it plays back on a dvd player.
    Any thoughts, this could take a real long time to rip part by part, fuse the VOBs and then convert. Can a edit the "unreferenced material" so that DVD Shrink thinks its part of the regular movie. I can easily edit just the clips / chapters that I need from there. And its really the only tool I know how to do this with.
    THX, JNT
    For the love of God, use hub/core labels on your Recordable Discs!
  2. Member Ozzyjim's Avatar
    Gday,
    Is this disc protected?, if not why can't you copy the VOB's to you HDD in windows etc then edit/convert from there.
    James.
  3. Member Dv8ted2's Avatar
    If you tell dvdshrink to rip the full disc, the unreferenced material gets ripped as well, provided you do not uncheck the boxes.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  4. The disk is not protected.
    Yes, DVD Shrink can rip the whole disk, but I need to rip it in parts so that I can encode each clip to WMV. The way it rips now, most of what I need to encode is in the unreferenced material and the clips are mixed around.
  5. VH Veteran jimmalenko's Avatar
    I would use DVDDecrypter in IFO mode with file-splitting set to none so that it dumps each PGC out to 1 VOB file. I do this on my TV episode DVDs all the time. I find it easiest to make a batch file script to do it - I can post it here if you are interested.
    If in doubt, Google it.
  1. How can I rip a badly made DVD?
    By semmel in forum DVD Ripping
    Last Post: 14th Jul 2007, 11:34
  2. Error while trying to rip an home made dvd
    By cd090580 in forum DVD Ripping
    Last Post: 19th Jan 2006, 16:30
  3. Can't Rip This DVD...STRANGE
    By hech54 in forum DVD Ripping
    Last Post: 10th Dec 2004, 15:39
  4. Replies: 5
    Last Post: 5th Mar 2004, 21:43
  5. Replies: 2
    Last Post: 26th May 2002, 10:07
About   Advertise   Forum   RSS Feeds   Statistics   Tools
