Hello, I'm using Avidemux v2.4.1 under Ubuntu 8.04, for DVD ripping, and I've encountered a problem at the audio tracks. Everything in the generated archive is correct, but you can hear the voices from the movie only in a channel. I discovered this because I was listening the generated archive using headphones. All the ambiental sounds and effect sounds are present at both channels, but the voices from the characters only is present at one. These are the steps I follow to rip the movie:
- First I rip the DVD archives using DVDShrink-Wine. At this point the voices are OK. With DVDShrink I only select an audio track.
- With Avidemux I select "MPEG-4 ASP (Xvid4)" for the video, "Two-Pass" with average bitrate (1500), "Chroma optimizer", "VHQ Mode: 4" and I use the filters "Crop" and "MPlayer Resize".
- With audio, I select "AC3 (lavc)" (I selected "MP3 LAME" with the same results) and at Config I only select the bitrate (192). At sound filters, I only change the Gain (Manual: 5). I leave the rest of the config as it.
I want to know how to mix the sound so I can hear all the sound at both channels. I have no problem with the TV, but when I view a film using headphones is very irritating.
And sorry for my english :P
Thank you for the help
Was the original audio 5.1 ? Did you use the mixer to downmix (it seems like the downmix wasn't done correctly)
Try a more recent version, 2.4.1 is an ancient build
dvd subedit turkish character problem
By siddharta in forum SubtitleReplies: 0Last Post: 28th Nov 2009, 21:44 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Japanese character is showed as different character in subtitle workshop
By yunakokimama in forum SubtitleReplies: 0Last Post: 8th Apr 2007, 00:57 -
Converting 6-channel to mesh with 2-channel tmpgenc dvd
By lockheede in forum DVD RippingReplies: 2Last Post: 18th Oct 2005, 20:27 -
How to play only one channel ?
By Secx in forum Software PlayingReplies: 1Last Post: 25th Jul 2002, 00:44
Statistics
Newest guides
Latest tool updates
New media comments
