    It was working fine and all of a sudden it stop recognizing the blank media. I am always asked to insert an empty disc.
    I bought this 2 weeks ago. I already tried uninstalling the driver and system restore. I tried several media brands with the same result. Any ideas?
  2. Member Dv8ted2's Avatar
    You could try updating the firmware for the drive. It could also be a dirty lens or the laser could be going out. I would try updating the firmware first. The drive might not be capable of handling new media until the firmware update.
    Believing yourself to be secure only takes one cracker to dispel your belief.
    Thanks for the quick reply. I already checked and the newest firmware is already installed. Could the lens really be dirty after 2 weeks?
  4. Member Dv8ted2's Avatar
    There are any number of explanations. Bad media - dirty lens - or defective drive. The length of time owned has no bearing on defective equipment or dirty lens.
    Do you smoke in the house? Many optical devices die thanks to smoke, be it cigarettes, cigars, or something else.
    In response to your PM, no, don't use a "cleaning disc" -- those are often abrasive, and don't help anything. Follow this guide instead: http://www.digitalfaq.com/forum/show...vd-cd-423.html
  7. if it's really only 2 weeks old and had a problem like that i would take/send it back and exchange it as defective.
  8. Uninstall any software (NERO, PRASSI, ROXIO) you have put on recently .. some such as daemon or imgdisk can sometimes cause problems with the aspi layer. Try using your drive under linux or win7 to make sure its the hardware at fault.
    You could try spitting on the lens and rubbing it with a damp cloth, it always brings my HorseBrass up in a real shine, although nine members of my Family have died from Swine Flu
    You are being extremely secretive about the make? the model? and the type(s) of media? software?
    If this information is deemed classified then I understand ... else ...
    The electronic components of the power part adopted a lot of Rubycons.
  1. Erased -RWs no longer recognized - HELP!
    By will7370 in forum Newbie / General discussions
    Last Post: 5th May 2009, 19:08
  2. Capture devices no longer recognized by XP
    By civuck in forum Capturing
    Last Post: 30th Jul 2005, 21:28
  3. Pioneer DVR-106 no longer recognized properly after XP insta
    By EdgarFriendly in forum DVD & Blu-ray Writers
    Last Post: 13th May 2004, 21:19
  4. Replies: 5
    Last Post: 13th May 2004, 19:51
  5. Media Player no longer plays dvd audio suggests?
    By baritony in forum Software Playing
    Last Post: 23rd Nov 2003, 06:08
About   Advertise   Forum   RSS Feeds   Statistics   Tools
