I have a mkv file, which is 1920x816 (AR2.35:1).
When I try to convert it to BD, PowerDVD plays it in full screen mode (16:9). Everything looks stretched vertically of course.
Is there a fats way, to change the AR? I tried to reconvert with MP4Box/yamb/mkvmergeGui etc, but always with the same result.
I'm now trying to reconvert with Handbrake, but this takes very long. Please advise, how to accomplish this.
Have you tried multiAVCHD? and maybe you need to use uncropmkv.
Thanks for the advice. But uncropmkv seems to do nothing (because the mkv file was not changed at all).Am I missing something?
You need to add the borders back to make it full frame 1920x1080 like the original blu-ray. This requires re-encoding
(1080-816)/2 = 132 pixels to the top and bottom
Yes, I understand that now. I hoped, there was a shortcut, as handbrake took about 5 hours to convert a 2.5h movie.
I eventually got uncropmkv running (reinstalled Avisynth), but PowerDVD doesn't recognize the BD disk I created with MulitAVCHD.
I think, it has some to do with the sound track, as the first BD (done with Handbrake) has no sound at all.
I keep on trying. Thanks anyway for the valuable advice.
Eventually I got things working.
Trouble was, that after changing my graphic card from ATI to NVIDIA, some ATI codecs still remained on my machine. After removing them in the registry and filter settings. Everything works fine now.
BTW, ARCSoft MediaTheatre is much better in dealing with Blu Ray material than PowerDVD.
You can try to change the (MKV) files display size info with header editor (so it displays that AR when the movie plays)in MKMerge it's in the file menu.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 2nd Mar 2012, 15:25 -
MKV file displaying wrong aspect ratio on Bluray player.
By djfonti in forum Video ConversionReplies: 11Last Post: 5th Sep 2011, 20:05 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Apr 2010, 23:07 -
DVD to x264 mkv gets wrong aspect ratio
By kramboa in forum DVD RippingReplies: 8Last Post: 3rd Nov 2009, 10:28 -
Playstation 3 Blu-ray playback of scratched discs, 1:1 aspect ratio?
By creakndale in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Apr 2008, 12:22
