VideoHelp.com Forum
    Hello guys...
    I recently bought a cannon HG10 camcorder which records in M2TS format.
    putting the video files to a dvd is not a problem to playback.
    However i would like to join the files together so i could watch the video in HD on my
    PS3 The software that i got with the camera is a bit lame. After converting and making a menu after each file is
    played it stops and then i have to select the next file manually to play.
    The software being DVD MovieFactory SE.
    Even on the menu screen the chapter names are for each file that is on the Disc.
    I have tried using Tmuxer and adding/appeninding each file and using the create blu ray disc option.
    But after i write the disc off it just says BD data with no files showing.
    Any ideas are welcome..
    TIA
    Wazza
    in tsmuxer "create blu-ray disc" refers to BD25, not BD5/9, you want "AVCHD" option for DVD media. Check to make sure you are using a current revision
    thnx will give it a try.. was using an older version
  4. Mr. Computer Geek dannyboy48888's Avatar
    concure , should definately work, unless you are using V 1.10.3 then you NEED to get the latest version of tsmuxer (1.10.6) (has problems finding files.....)
    if all else fails read the damn manual
  1. Mux several MKV files to several m2ts files
    By jomoe in forum Video Conversion
    Last Post: 10th Feb 2012, 03:14
  2. Help with multiple .m2ts files to one .m2ts
    By neworldman in forum Blu-ray Ripping
    Last Post: 17th Mar 2010, 19:39
  3. How to convert m2ts files to mp4 files with sound
    By diets in forum Blu-ray Ripping
    Last Post: 18th Jan 2010, 11:17
  4. Converting m2ts files to more manigable files
    By soledsoled in forum ffmpegX general discussion
    Last Post: 22nd Jun 2008, 20:49
  5. Replies: 8
    Last Post: 2nd Mar 2008, 20:51
