What software can I use on Vista Home machine to broadcast live video and record it, i.e. save it
to a file at the same time?
I have an NTSC signal that I am able to http stream using free Windows Media Encoder 9.
But it does not record while it streams. There was some information that I could try
using a DirectShow compliant software, but I am unable to find such a software.
I am able to use Corel VideoStudio to record the file to MPEG, but it does not stream.
Running both software at the same time does not work as they are using the same driver.
Not that it matters but I am using a Belkin composite to USB adapter "Hi-Speed USB 2.0 DVD Creator".
I have experimented with a Haupaugue vide card.
Thanks,
Rio
VLc Media Player might work, use the wizard mode to set up the streaming.
Thanks, I just went there an entered the following question.
One problem is that is gnu licensed, and I want to use this at work on a private subnet. It is difficult or impossible to use gnu license software in this subnet.
Would I be able to use VLC to stream a live NTSC signal and capture/encode/recored it simultaneously?
A first glance at the HowTo shows the wizard providing the option to either stream or save to a file,
but no option to both stream and save.
Thanks,
Rio
One solution i can think of is to use Windows Media Encoder 9 to stream the video, then use Camtasia or Snag-it to do a screen capture you may have to create a loop back between your sound cards speaker out and Microphone jacks.
I haven't tried this method but it seem feasible.
Unable to record this live stream - any thoughts ?
By DB83 in forum Video StreamingReplies: 3Last Post: 14th Jan 2011, 12:39 -
My new capture card can record and playback, but won't live stream. :-/
By Deadlight7 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2010, 23:50 -
Sending files to USB hard drive with WDTV live
By neworldman in forum Media Center PC / MediaCentersReplies: 2Last Post: 13th Jan 2010, 16:33 -
Suggestions on how to record live video to hard drive
By bnchs in forum Video StreamingReplies: 5Last Post: 29th Aug 2009, 12:38 -
How to record video from camcorder and stream live simultaneously
By bnchs in forum Video StreamingReplies: 2Last Post: 27th Aug 2009, 13:28
Statistics
Newest guides
Latest tool updates
New media comments
