I just recorded my first "Blu-ray" DVD from an MKV file since upgrading Imageburn.
There were no errors reported by the software, yet when I played it on my Panasonic BD player, it said "not supported". Never got that with the previous Imageburn version.
I know settings are lost when upgrading, did set profile level to 4.1, UDF 2.50, and checked Recurse Subdirectories.
Am I missing something, any clues?
Results 1 to 13 of 13
You could go backwards and use the previous version, since that version worked for you.
Believing yourself to be secure only takes one cracker to dispel your belief.
Do you think it's best to do a system restore or uninstall 2.4.40 and look for the previous version?
System restore is not necessary. Just unistall and look for the previous version.Originally Posted by jfreytagBelieving yourself to be secure only takes one cracker to dispel your belief.
Just uninstall and reinstall the older version.
I actually went back to 2.4.2.0 because when 2.4.3.0 was released there were quite a few bugs, a couple i had were not even mentioned and when i tried to post them on the official site it would not let me.
I also had a couple of things happen on 2.4.4.0 that annoyed me more then any problems with it burning and 2.4.2.0 still works just fine and i never had any problems with it so.....Originally a member since 2001, LONG LIVE TARAN's!!!
this is not an imgburn problem...if you sent the proper folders to imgburn it will burn bluray fine....this version works perfectly as I have tried it. It is your player. you need to research if your player supports video on bd-r....most players DO NOT play video on bd-r. You need to check this first...what is the model
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Originally Posted by ron spencer
He said it worked before the IMGBurn update. I guess you missed that.
Thanks guys, will go back to previous version and try again. Dv8, It's actually a DVD-R with AVCHD I'm burning. My standalone player is a Panasonic BD-55.
This could either be bad discs or your optical drive. The lens might be dirty or the laser might be going out. Try different discs first.
Will do, thanks!
Ok I replaced the DVD drive and don't get an error now during recording. But same problem "unsupported" when played on my standalone player.
All I do is open Imageburn, add BDMV and CERTIFICATE folders, ensure it's set to UDF 2.50, Recurse Subdirectories checked, and burn. No errors reported by Imageburn.
Strange thing is it's the same routine I used to follow up until a few days ago, and worked fine on my player.
I installed MeGUI and Mediaoinfo ever since, I don't suppose that would matter. Those are all the changes to my PC before this problem started.
Need help with upgrading
By jaywestcwf in forum CapturingReplies: 2Last Post: 10th Feb 2010, 10:19 -
imageburn how to
By natty in forum Newbie / General discussionsReplies: 4Last Post: 27th Apr 2009, 20:15 -
How to create a DVD using ImageBurn?
By pmolson in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2008, 03:18 -
Making A firmware Update Disc Using ImageBurn Software
By tyfos80 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2008, 09:29 -
unable to install vlc,imageburn,alchol,deamon tools.
By jackyshaikh in forum ComputerReplies: 6Last Post: 9th Jun 2008, 07:10
