I am trying to get some m2ts blu-ray 1080p video files to play on my friend's PS3.
1. Is it possible to just copy an m2ts file to USB stick or DVD and have the PS3 recognize it and play it as 1080p?...or do I have to burn it on DVD?
2. Do the files need to be a certain size to play correctly or it it doesn't matter?
Thanks.
I apologize if this has been asked before.
Thread: m2ts for PS3 on USB stick or DVD
You can put m2ts files onto a DVD-RW and the PS3 will play them.
If you want to play them off a USB stick, I would recommend using multiAVCHD to create an AVCHD for USB structure and putting that on the USB stick.
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum CapturingReplies: 9Last Post: 6th Mar 2012, 18:57 -
Watch DVD WITH Menus from Hard Drive and USB Stick
By Squirl1899 in forum Newbie / General discussionsReplies: 6Last Post: 4th Oct 2011, 13:25 -
Convert FLV for DVD Player on USB stick
By rob_g9 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 08:10 -
M2TS file plays from PC to Xbox no problem but will not play from USB stick
By FuzzyReets in forum Video StreamingReplies: 3Last Post: 6th Nov 2010, 07:31 -
Watch DVD on Fash USB Stick/Disk on Home Cinema
By mdagis in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2010, 10:06
Statistics
Newest guides
Latest tool updates
New media comments
