VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Member dudeman316's Avatar
    Originally Posted by manono
    Different movies, so it's an apples to oranges comparison.
    I have 3 suggestions. The first would be to do a fast 1-pass Quant 3 encode and see if it looks OK. If so, is it much larger than the 2-pass one you did? Since the final file size shouldn't be important to you, you should probably be doing this anyway.
    Second, what Custom Matrix are you using? Maybe your player can't decode it properly. You might try one of the standard matrices, H.263 or MPEG and see if it looks any better.
    Third, cut out a small piece for upload somewhere so we can see what you're talking about.
    How do I change it in AutoGK to fast 1-pass Quant 3 & how can I get it to use h.263 Matrix?
    Father knows best.
    Select single pass and push the quality up to 95%. Note : the file size will be huge, and quite probably go over the 2GB limit that most Divx players choke on.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member T-Fish's Avatar
    iirc according to len0x, everything over 75% is a waste.
    Quality is in the eye of the beholder. Some people believe anything over 700 MB is waste.
    There is a difference above 75 in AutoGK. The question is at what point do you either stop seeing any change, or do the file sizes become too big. At what point quality changes stop being visible will vary from source to source.
    For me the irony is that having seen some of the videos of which the OP speaks, well, they are nothing special, and certainly not that great a quality.
  5. Member Dv8ted2's Avatar
    I agree...
    He is not understanding that the quality is only getting worse.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  6. Originally Posted by dudeman316
    Read my post just after that one where I modify the suggestions for use in AutoGK.
  7. Hello dude
    Did you try the setting I have suggested? Give it a try. I did a movie with it, and my friend was quite surprised with the output quality.
    BTW, for my old rig AGK takes just about 2.5hrs to convert a movie of of 2hrs length.
    আমি বাংলায় গান গাই
    Be sure to use a version of Xvid with Adaptive Quantization.
  9. Originally Posted by jagabo
    I think the latest version of AGK with latest Xvid already incorporates Adaptive quantization.
    আমি বাংলায় গান গাই
  1. Are dvd rips RBG or YUV?
    By dioxholster in forum Newbie / General discussions
    Last Post: 23rd Apr 2012, 06:14
  2. DVD and Blu-Ray rips
    By ldoodle in forum Blu-ray Ripping
    Last Post: 22nd Sep 2009, 22:11
  3. DVD Rips Taking Up Too Much Space
    By vidvidhh in forum Newbie / General discussions
    Last Post: 29th Jun 2009, 01:38
  4. Best all-purpose format for DVD rips
    By studawg66 in forum Video Conversion
    Last Post: 3rd Sep 2008, 11:49
  5. DVD RIPS (non copyrighted) for educational use...
    By Spooky_uk in forum Newbie / General discussions
    Last Post: 30th May 2007, 18:33
