I'm recording TV shows and movies via Satellite, SD and HD streams, which include DVB subtitles streams, which I'd like to keep. SD files are MPEG-2, while HD files are h264 video and ac3 audio.
I want to trim those files at the beginning and end, while keeping everything intact.
I managed to do it for SD files with ProjectX, however, I cannot open HD files with it. I get an error message:
Error while encoding frame
Not enough data in buffer .
I tried TS Packet Editor, but I cannot open either files. I get an error message:
Error: Removing DirectShow objects
Specified cast is not valid.
Error Loading Video, Disabling.
Also, H264TS Cutter fail to open my files.
Note:
The recordings are done with SageTV and DVB-S2 card.
Any ideas?
Thread: Trimming DVB *.ts files?
ProjectX doesn't handle h264 format. If you cannot open HD .ts in two other programs, the stream has to be full of errors or at least it has corrupted structure. You may also try tsMuxeR.
BTW: Much better and cheaper is DVB Viewer.
TS Packet Editor and H264TS Cutter couldn't open my files, probably because they don't recognize the DVB subtitles stream.
I tried tsMuxeR and it notifies me it doesn't recognize the DVB subtitles stream.
The video ts files are fine, because I can view them, including the subtitles, with MediaPortal.
So, I just paid for DVBViewer and it cannot open (play) my ts files.
May be I can get support at their forum, and may be not.
Any other ideas?
Try to record a HD stream in DVB Viewer. What is strength (%) of the signal? If the signal bar is displayed in yellow (I think it's then below 40%) then you may get errors.
Recording in DVBViewer is no good for me. There is a gismo software that creates 6 virtual tuners out of 3 physical ones, and I need it. It works only with SageTV. Also, it uses joker's NDSCAM to open my satellite Smart Card in order to view the channels I'm subscribed to, which I doubt DVBViewer would be able to do.
Moreover, I managed to open a small ts file with DVBViewer, however, there was no option for trimming the file (cutting few minutes at the beginning and end of the movie).
As I wrote before, the signal strength is fine and the ts files are fine, since they are being plaid by MediaPortal.
BTW, I get signal strength 70 and quality 100.
Converting DVB-S2 TS files
By dstu in forum Video ConversionReplies: 10Last Post: 29th Feb 2012, 04:27 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / HDTVReplies: 1Last Post: 19th May 2011, 05:38 -
Re-editing digital on-screen graphic on MPEG files saved from DVB-T
By ANOther1676 in forum EditingReplies: 3Last Post: 17th Dec 2010, 17:23 -
converting TS files from DVB broadcastings (cablecompanys)
By madlenp in forum Video ConversionReplies: 1Last Post: 22nd Sep 2008, 04:47 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 07:02
