Hi
I recently downloaded one video split in 4 parts. However they come with "Document" or "File" format, and they are named like this:
example.avi.01
example.avi.02
example.avi.03
example.avi.04
I tried to merge them with regular programs that I downloaded, but they don´t recognize them as video files, so therefore I cannot merge them into one video. How is it done??
Thanks!
Results 1 to 9 of 9
It is possible that the programs you tried don't recognize the file extensions. Try to rename them to something like
example01.avi
example.avi.01In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Assuming it's been split "cleanly", try something like this from a command prompt in the folder where the files are...
COPY /B example.avi.01+example.avi.02+example.avi.03 combined.avi
Trev
(now try & do that from GUI!) -
Sometimes files named like that are rar or par files,try using 7-zip to join them using the first .01 file.
The files were at the end with the following index "avi.001" (example.avi.001) that is why HJ Slip recognize it, but I have others that are "avi.0", "avi.1", etc and HJ Slip doesn´t recognize them :S. For some reason they should be "avi.001". How do I merge the new ones??
7-zip,much better than HJ Split,will join most types of files were HJ Split cant.
I solved it already... just needed to rename the files as .001, .002, etc files and join them later with HJ Split.
Thanks to all for the effort anyways!! ;o)
How can I get windows search to recognize mkv files as "video"
By cuttlass in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2011, 00:13 -
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 13:18 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
