VideoHelp.com Forum
    My philips dvdr3460H, stops showing subtitles on the middle of some divx film, without reason.
    I try in PC, and everything goes well.
    It hapens only in some films.
    Could you help me.
    Thanks in advance
  2. Member Krispy Kritter's Avatar
    I can only assume you are using external subtitle files. It's possible the files are damaged or don't adhere to the spec. They may also just have a glitch in them, especially if two parts were merged together. A PC can often overcome many issues with various types of files that a standalone player can't handle. You might also have a problem if the movie is in two parts (movie cd1.avi, movie cd1.srt, movie cd2.avi, movie cd2.srt). The philips players that I've used, will automatically go from movie cd1.avi to movie cd2.avi, often without a pause, but the subs have to be manually started.
    Google is your Friend
    Philips DVD players that support Divx may have problems if there are any errors or weird characters in the subtitles file. I edited a subtitles file on a Linux server and my DVP-642 refused to play it until I opened the file under Word Pad and saved it under Windows. You'll have to manually look at the subtitles file at the point where it stops and look for errors or strange characters. You may have to use a binary editor to see if any control characters are at the point where it stops.
  1. Problem with Philips DVDR-3505
    By obolon84 in forum DVD & Blu-ray Recorders
    Last Post: 12th Jul 2010, 09:54
  2. Philips Recorder DVDR 5570 - DIVX subtitles not copied and not displayed
    By Radio1040 in forum DVD & Blu-ray Recorders
    Last Post: 3rd Mar 2009, 01:18
  3. philips dvdr 3455h
    By mikes94547 in forum DVD & Blu-ray Recorders
    Last Post: 24th Dec 2008, 09:36
  4. Problem with Philips DVDR 3460H
    By sonybetamax in forum DVD & Blu-ray Recorders
    Last Post: 21st Sep 2007, 14:59
  5. Philips DVDR 3475
    By cabralmj in forum DVD & Blu-ray Recorders
    Last Post: 13th Jul 2007, 15:46
