VideoHelp.com Forum
Results 1 to 12 of 12
    Hi
    Does anyone have the unlock code by remote for my Philips DVP3360 please?
    Thanks in advnce
    Dave
  2. Member bmwracer's Avatar
    My guess would be that's it's the same as the other Philips DVD players... At least it's worth a try, huh?
    Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
    There may not be an unlock code for this model. All players can't be unlocked. A few years ago Philips just about didn't make any players that couldn't be unlocked, but now we're getting posts about various Philips models that can't be unlocked. Hollywood has gotten to almost all of the major manufacturers and convinced them to stop making DVD players that can be unlocked. Exactly what this is supposed to accomplish is a great question as it will surely lead to even more piracy and fewer sales, but nobody in Hollywood seems smart enough to figure that out.
    Maybe you will get lucky and someone will post an unlock code that works.
    I can't recommend that you just try some other model's unlock code as there is always a chance that you might destroy your player doing that. If you are sure you can take it back if it gets bricked, then you might try that.
    LOL It always disturbs me when you write that. It sounds like you are saying "no players can be unlocked", rather than, "only some players can be unlocked".
  5. Greetings Supreme2k's Avatar
    "Not all players can be unlocked"?
    "Unlocking on players is not 100%"?
    "The amount of players that can be unlocked is less than total"?
    jagabo - Point well taken. I'll go with one of Supreme2k's suggestions, probably the first one.
    i have to admit the unit has not arrived yet so can not try the older ways of doing yet.
    Would be gratful if anyone has managed hack one to say how they did it, to post
    TIA
    The old hack for the DVP3020 work:
    1. Press the Setup button on your remote control
    2. Using your remote control, highlight but do not select the Preferences menu
    3. Press the 1 button on your remote control
    4. Press the 3 button on your remote control
    5. Press the 8 button on your remote control
    6. Press the 9 button on your remote control
    7. Press the 3 button on your remote control
    8. Press the 1 button on your remote control
    9. Using the Up and Down buttons on your remote control select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    10. Press the Enter button on your remote control
    11. Press the Setup button on your remote control
    Just registered to share this. I just bought my Philips DVP3360/12 ... 10 mins ago
    I just bought my Philips DVP3360/55 region 4 and I read the crius way and It Worked now I can play dvd´s region 1
    My Preferences menu button is greyed out.
    How can I access it?
    I think he left out this:
    0.	 Remove disc from tray
    YES! YES! It works - that is great! Thanks so much!
  1. Samsung BD-P1600 - Region Free Unlock code
    By kennyt in forum Blu-ray Ripping
    Last Post: 5th Dec 2011, 01:15
  2. Panasonic SA Ht720 Region Unlock Code
    By JeffroBrazil in forum DVD & Blu-ray Players
    Last Post: 10th Nov 2011, 08:29
  3. Unlock region code for Panasonic DVD-S1
    By Jurgs in forum User guides
    Last Post: 4th Jan 2011, 22:17
  4. Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
    By aexp in forum DVD & Blu-ray Players
    Last Post: 3rd Sep 2009, 10:24
  5. Region Code Unlock for LG DR 4800 ?
    By carletto in forum DVD & Blu-ray Recorders
    Last Post: 12th Jul 2009, 11:04
