I have been burning MKV HD files onto DVD's for a while now without a problem. I then play them back on a Panasonic DMP-BD55 set top Blu-ray player. Only two days ago had a problem for the first time.
I use tsmuxer to create the standard folders, and Imageburn to burn them to a DVD. If I need to split the mkv to burn on multiple DVD5's, I use mkvmerge.
The last two DVD's I created, when played on the Panny, there is no video output, black screen. Audio is fine and counter on the player moves forward as usual.
When I play the m2ts file from the burned DVD in the computer, there is video signal. Previously created AVCHD files play fine on the player, I checked.
I didn't change any settings on tsmuxer or imageburn when this started happening.
Anyone else had this problem?
Any ideas?
Thanks!
Results 1 to 9 of 9
It could be that the video specs in the mkv non-compliant with avchd (e.g. might have too many reference frames or use b-pyramid). If you didn't change the tsmuxer version, this is likely the case. You can use mediainfo (view=>text) for more info on the video specs of the mkv. If this is the case, there is not much you can do short of re-encoding to compliant specs
Thank you! I have upgraded to tsmuxer 1.10.6, but not tested yet.
Here are the specs from Mediainfo, any links where I can check what to look for to see if they are compliant?
Also, I see a new option on tsmuxer "create AVCHD disk". I always use "create Blu-ray disk". What is the new option for?
Format : Matroska
File size : 7.95 GiB
Duration : 2h 14mn
Overall bit rate : 8 454 Kbps
Encoded date : UTC 2007-05-17 19:16:37
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Mar 5 2007 12:54:12
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : Main@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 14mn
Bit rate : 7 646 Kbps
Nominal bit rate : 7 812 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Stream size : 7.18 GiB (90%)
Writing library : x264 core 54
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x1:0 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=7812 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 14mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 616 MiB (8%)
There is no magic button, just look them up, the settings have been covered in numerous threads and most encoder GUI's have presets for standalones.
Your video is not compliant, it won't play on the majority of standalone players. b-pyramid=1, and no VBV buffer.
blu ray is for blu ray (bd25/50), avchd is for avchd (usually used for BD5/9) , the specs are different
Thanks for the info.
Could the resolution be a problem as well? I see it's 1280x688, instead of 1280x720.
Also, the profile is 5.1 and I had read in a Bitburners.com tutorial that anything higher than 4.1 should be set back to that on tsmuxer. Is this so?
The resolution has to be compliant (720 or 1080). Turning off the 24fps option in the setup menu helps with some videos also, mostly videos encoded with x264.
Playing a 30p AVCHD disc
By Michael33 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2011, 11:40 -
AVCHD Files not playing in VLC, MPC
By Desp in forum Newbie / General discussionsReplies: 19Last Post: 22nd Sep 2009, 15:06 -
Problems playing MTS/Avchd file
By statang in forum Software PlayingReplies: 7Last Post: 29th Jul 2009, 03:13 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 29th Oct 2007, 11:54 -
Playing AVCHD DIsk
By nirbhayn in forum Camcorders (DV/HDV/AVCHD)Replies: 6Last Post: 29th Oct 2007, 09:00
