Hey ChrissyBoy,
I was wondering if there was a way to make navigation to the output folder easier in 2 ways:
1. If it could default select the Output folder similar to how it was in version 2.5 where it automatically selected the same folder you chose for the original DVD.
2. By allowing users to easily select the Desktop folder. As it stands now, you have to navigate to the C drive, Documents and Settings, the current User and thence to the Desktop folder. This could be easily circumvented by adding a back folder button/icon to simplify navigation.
EDIT: Upon a little more investigation I've discovered that the file directory allowed you when you browse to select which folder the DVD is in is actually a different interface than that with which you choose the Output folder. Maybe making the Output directory similar to the DVD directory is what will rectify this situation?
I appreciate your hardwork!
Most people reuse the same output folder. To this end the "last" output folder is the default when you browse.
Is this not good?
Also the output browse and the input browse dialogs are for folders and file respectively – they are different for that reason. Nothing I can do there.
FYI: I have added the desktop to the output folder dialog in the latest release.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Change output directory in Projectx 0.91
By ccc in forum Video ConversionReplies: 0Last Post: 8th Apr 2012, 19:26 -
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Cannot open the MPG file after extracting with VOB2MPG 3.0 PRO
By shira in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 17th Jan 2010, 08:50 -
No audio in preview or output MPG file in VOB2MPG 2.0
By scruzphreak in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2009, 12:20
Statistics
Newest guides
Latest tool updates
New media comments
