Hi!
I want to convert VHS to DVD. My computer has only one PCI-Express 16x free slot.
I have an onboard graphic card, which consumes the system memory. I'd like to buy a video card, so to gain more system memory.
What is the best choice? Purchasing an USB capture device and a video card, or a video card that can capture?
I'm affraid that video card that can capture would be less performatic than an USB capture device.
What do you think?
Thanks in advance!![]()
Best regards,
Joelson.
Either should work fine. It boils down to personal preference. I've had good luck with the ATI All-In-Wonder cards in the past.
Google is your Friend
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video StreamingReplies: 1Last Post: 15th May 2009, 14:56 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum CapturingReplies: 3Last Post: 15th Sep 2008, 02:48 -
Video capture card help! How do you capture from video card (desktop)?
By AtiMike in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2008, 16:50 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum CapturingReplies: 14Last Post: 18th Jan 2008, 21:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum CapturingReplies: 1Last Post: 6th May 2007, 17:15
Statistics
Newest guides
Latest tool updates
New media comments
