Using Mainconcept Reference to convert a Mkv to Avchd since tsMuxeR doesn't recognize the video part, probably due to it not being Avchd video compliant.
Problem is the source audio source is 6ch/ or 5.1 and Mainconcept only shows 2ch audio for ANY FILE...
What gives with this, do i need an addtional plugin?
Thanks to all that can help.
What kind of audio (e.g 6-ch aac, ac3, dts ?) , and you have the corresponding plugin(s) activated ?
MCR will use a directshow import for mkv files so you need to ensure your directshow filter chain is clean (not downmixing to stereo). e.g. if you are using ffdshow to decode audio, make sure the mixer isn't set to 2-ch
Also have you tried the beta tsmuxer versions? it should be able to identify the video (even if not avchd compliant)
Ok tried tsMuxeR v10 beta, recognized the video this time, 100% complete but returned error code -2, INVALID media type 15.Originally Posted by poisondeathray
Even made a certificate folder, unlike all the other times I used the program.
Imgburned anyway, would not play...
Frameserve from Premiere CS4 to MainConcept Reference
By nharikrishna in forum EditingReplies: 5Last Post: 13th Dec 2011, 21:42 -
How to compress a video to 1MB/min with MainConcept Reference?
By Bob2267 in forum Video ConversionReplies: 7Last Post: 25th Aug 2011, 01:11 -
MXF with JPEG2000 codec in Mainconcept Reference
By lord25 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 09:34 -
multichannel audio in MainConcept Reference
By lord25 in forum AudioReplies: 15Last Post: 2nd Apr 2009, 15:03 -
AC3 (5.1 or 2ch) to 2ch mp3
By shun in forum AudioReplies: 4Last Post: 11th Nov 2008, 07:50
Statistics
Newest guides
Latest tool updates
New media comments
