VideoHelp.com Forum
    When I go to Roboform's options, under Security you can choose among the following encryption algorithms:
    -DES
    -3DES
    -AES
    -Blowfish
    -RC6
    By default it's set to AES. Is this the safest one? If not, which one? Thanks
  2. they are all fine. it's only encrypting what is stored on your computer and any of those will stop anyone without an nsa badge.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    AES with a 256 bit key is about as secure as you can get. http://en.wikipedia.org/wiki/Advance...ption_Standard
    alegator,
    Given those choices, and with all other things being equal, I would use either Blowfish or AES.
    The NSA believes AES is sufficient for protecting even top secret government documents (even when using only 192 of the possible 256 bit key size), and the NSA is very good at their job. As a rule, it's best to consider expert advice.
    Blowfish is older, but (the last I heard) is still unbroken, which gives it more of a proven track record. Blowfish also allows a 448 bit key.
    Of course, the best encryption algorithm in the world won't offset a weak password. If you google "strong password", you should be able to come up with a password that makes the most of whatever algorithm you choose.
  5. Member Marvingj's Avatar
    But actually security level is determined by the weakest link. In case if strong cryptography is used, the weakest link is a password - it could be guessed much easily than encryption key. Computers become faster every year. And common practice is to increase complexity of password testing process in new versions of software.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    Thanks everyone for their replies. Now, the way roboform works is that it stores the login information for a user's commonly accessed websites (username+password). It will only provide and fill the login info once the user logs in the program by means of a password that the user sets. So the question is, who cares how safe is the encryption method? I mean, if the program's access password is weak enough, someone can guess it or decypher it and then access all the encrypted login records stored in Roboform. ???
  1. New Adobe Photoshop image deblurring algorithm
    By poisondeathray in forum Latest Video News
    Last Post: 13th Oct 2011, 23:12
  2. Algorithm convert DAT to AVI
    By Nemo_wf in forum Video Conversion
    Last Post: 5th May 2010, 03:18
  3. Understanding RGB filter algorithm
    By brianwarming in forum Programming
    Last Post: 6th Feb 2009, 21:16
  4. Replies: 3
    Last Post: 2nd Feb 2008, 15:03
  5. Replies: 3
    Last Post: 4th Jan 2008, 22:19
