VideoHelp.com Forum
    Quite a few of the x264 videos I've captured with my Hauppauge HD-PVR have a slight audio sync problem. Does anyone know anything that will let me adjust the audio, either when in TS or MKV format?
    Thanks.
    have you tried tsmuxer or mkvmerge (mkvtoolnix) and see if you can adjust some audio time delay settings?
    Hi Balders
    Thanks. I'm trying tsMuxer. Interestingly, the ones that are our of sync all report as having audio of -91ms. Not sure why that's so! All are captured from the Hauppauge PVR, and 3 out of 4 play back fine! I'm going to trying remuxing the captured TS files to TS with the audio corrected, and then remux to mkv.
  1. Audio out of sync in MKV file.
    By Colin-uk in forum Video Conversion
    Last Post: 14th Oct 2011, 12:50
  2. how to correct out of sync video/audio in mkv file
    By 55trucker in forum Video Conversion
    Last Post: 22nd Mar 2011, 11:08
  3. Any way to change audio in MKV file?
    By Timmychuck in forum Audio
    Last Post: 18th May 2009, 02:22
  4. Audio Sync problems with MKV file using WMP
    By jradams76 in forum Software Playing
    Last Post: 23rd Jul 2007, 11:51
