How do I load a demuxed H264 file onto a script that works?
I have tried several ways and they are rejected by AvsP.
Which is the correct way to do it?
Results 1 to 22 of 22
directshowsource("c:\path to\yourvideo.h264",audio=false)
Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Or just dont bother with the demux and use something like:
xxx would be the frame rate of the video file.Code:Directshowsource("myfile.mkv",fps=xxx, audio=false)
Still not working. It begins to load, but it timeouts after not being able to load with F5 on AvsP.Originally Posted by freebird73717
Do you have a directshow filter for h264? A combination of FFDShow and Haali Media Splitter works great for me with mkv and h264.
The reason I am demuxing this mkv file instead of processing it directly, is because what I am getting is an m2p file with the subtitles burned in.Originally Posted by mh2360
What do you mean if I have a directshow filter for h264? How do I know I have one? Do I have to set things differently than usual on directshow?Originally Posted by freebird73717
If the original file plays OK in Windows Media Player, then you should have all the required codecs and filters.
Did you test the playback of the raw h.264 in MPC or with a container?
ffdshow doesn't reliably decode raw avc properly in my experience. The Divx h.264 decoder generally does a better job
Another option is to use DGAVCIndex (similar to DGIndex for MPEG2 sources) to index it if the source is progressive (it has issues with interlaced h.264)
If they are burned in, then demuxing it won't do anything. They will still be burned in. If they are external subs, use mkvmerge to checkmark wanted items, uncheckmark unwanted items (i.e. remove subs), and re-wrap your .mkvThe reason I am demuxing this mkv file instead of processing it directly, is because what I am getting is an m2p file with the subtitles burned in.
You could also use avc2avi to place the h264 in an avi container.
I have two demuxed H264 files: one from MKVExtractGui and the other from DGAVCIndex. None of them plays in MPC. How do I exactly put an H264 in a container?Originally Posted by poisondeathray
I was advised to use DSS2 too, as being more precise, but I can't make it work either. Probably because the container is not right.ffdshow doesn't reliably decode raw avc properly in my experience. The Divx h.264 decoder generally does a better job
How do I know if the source is progressive? I already indexed the files with DGAVCIndex. How do I load them into a script? What I got was a dga file which I am not sure how to load.Another option is to use DGAVCIndex (similar to DGIndex for MPEG2 sources) to index it if the source is progressive (it has issues with interlaced h.264)
OK. That was it. The subs are external. I did remux it with mkvmerge and voilá: the new file is clean of ghost subs.If they are burned in, then demuxing it won't do anything. They will still be burned in. If they are external subs, use mkvmerge to checkmark wanted items, uncheckmark unwanted items (i.e. remove subs), and re-wrap your .mkv
Good!
If the starting point was a transport stream, it has better support for transport streams. Similarly mkvmerge has better support for mkv
Just for completeness, you would use DGAVCIndex in a similar way to DGIndex (have a look at the quickstart page) which I know that you can use
. The dga file is analogous to a d2v file for DGIndx
LoadPlugin("PATH\DGAVCDecode.dll")
AVCSource("file.dga")
What would be a likely transport stream there? .m2ts, .mts, .ts? Right?Originally Posted by poisondeathray
Great info, Poison. Thank you very much.Just for completeness, you would use DGAVCIndex in a similar way to DGIndex (have a look at the quickstart page) which I know that you can use
Any difference in starting a conversion from an mkv stream or a demuxed dga stream?
It would be easier with the container, not using a demuxed stream (often you have to edit the .dga file, to set the correct fps or you get sync issues - a raw avc stream has no fps information and is set to 25 by default). The benefit of using DGAVCIndex, is that it indexes the stream and is frame accurate. DirectShowSource() for linear seeks (plain encoding) should be fine, or as you said earlier DSS2()Any difference in starting a conversion from an mkv stream or a demuxed dga stream?
correct, eg. a blu-ray source, an AVCHD camcorder, or a hdtv capture are common examplesWhat would be a likely transport stream there? .m2ts, .mts, .ts? Right?
some demuxers give you a file with .h264 extension, you may need to change the extension to .264.
Maybe I'm old, but I miss the practical things we had in Win 3.X!Originally Posted by mgh
How do you change extensions in XP?
OK. Now let me tell you another different story, that is happening with a different film, which never happened before.
I have an MKV file stream that I converted with avisynth. Everything seems fine.
So I load everything onto DVDLab Pro, which is the program I author with. Already made hundreds DVDs with, so I think I know my way around it. I load the files, load my sub streams (that didn't come with the file) and burn the disc .
When I go check the vob files, below every single sub line, very small down below, there's a small line of characters. Not letters, sometimes numbers.
Now where did that come from?
I've already put up this question in DVDLab Pro forums, with no luck so far.
Any ideas?
Are you sure you did the .m2v asset was clean (not hardcoded) ? Check with a media player
To make this task short: went through the original MKV stream with mkvmerge too and remuxed onto a new MKV. That fixed the problem in that film too. Strange thing is there was not a sub stream listed there, but the remuxing seems to have fixed the problem.Originally Posted by poisondeathray
BTW: how and where do I check if an .m2v asset is clean?
Avisynth source loading?
By yugurya in forum EditingReplies: 5Last Post: 22nd Jan 2012, 13:57 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Loading m4v in Avisynth
By AlanHK in forum Video ConversionReplies: 7Last Post: 16th Sep 2009, 22:51 -
Understanding MKV loading in Avisynth
By carlmart in forum Video ConversionReplies: 38Last Post: 28th May 2009, 06:39
