has anyone successfully captured with 5.1 sound?
i have found ,as i know many have ,that the updated version of arcsoft tme fails on burn.the older version burns but doesn't support 5.1.
i have the 5.1 hd pvr drivers.
is it the tme ,or am i barking up the wrong tree?
Thread: hauppauge hd pvr/5.1 captures
I also have a HD-PVR from Hauppauge and I believe that I threw away the Arcsoft software CD as soon as I got it w/o even installing it. I capture everything with SageTV. Yes, it has 5.1 audioOriginally Posted by romanticwarrior
-milOtis
Yes, I've been capturing in 5.1 for a couple of months now with the Hauppauge HD PVR. You want to make sure you have Dolby Digital enabled in your High Definition Satellite or Cable receiver. I had to enable it in my Dish Network receiver. Well I don't even use the Arcsoft software to author blu-rays. I use TS Remux to make blu-ray files and burn them to disc with Nero Burning Rom.Originally Posted by romanticwarrior
The Arcsoft Capture software does a good job of recording. I like using GB PVR when I want to record overnight since its scheduler recorder is much simpler to use than Arcsoft.Originally Posted by milOtis
if you cannot capture 5.1 dolby with the PVR is one of 2 reasons.
1) The version of the build and software did not include 5.1 dolby
2) Your sat/cable receiver is set to to output audio other than dolby.
3) Not using optical cable.
Easy fix for these issues. For #1 go to Hauppauge site and download the file in the support section and and just load on your computer. #2 & #3 needs no explanation.
Dolby 5.1 is yours.
Hauppauge HD PVR
By Susan_T in forum Video StreamingReplies: 1Last Post: 21st Nov 2011, 20:06 -
Hauppauge HD PVR
By Susan_T in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2011, 15:20 -
WinFast PVR captures audio in PCM only
By jaceko in forum CapturingReplies: 4Last Post: 13th Sep 2009, 16:24 -
Hauppauge HD PVR
By karebo in forum DVB / HDTVReplies: 13Last Post: 6th Jun 2009, 08:57 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum CapturingReplies: 1Last Post: 11th Mar 2008, 09:04
