Is it possible to enbale the software to playback ripped BD from Hard Disk by any means? tweak, patch or anything?
Results 1 to 15 of 15
anybody looks at the threads in this forum!!!!!!!!!!!!!!!!!
Dont have blue ray player but I know a person who rips BlueRay to his harddrives and plays them with PowerDVD ... so ... there is a way .... but he lives about a 1000 miles away and ... well you can figure out the rest ... check the forums or ... google it
keywords I used in search >>> blue ray powerdvd 9
Try this >>>
http://unkool.com/misc/how-to-play-b...-on-powerdvd-9
Trial version of PowerDVD does not support Blu-ray Disc playback. So you have to purchase one.
Your behaviour ... is possibly not going to get you very far ... check the forums ... do a searchOriginally Posted by giosa
I not impatient in any way just this is not the first case of negligence in this forum! Thank you for answer anyway. Power DVD is total shit, seems there's no way to make it play ripped BDs. I got the link you gave me, but doesn't work with v9. Thanks.
Nope, it wont work. I would try ArcSoft TotalMedia Theatre instead. It works fine for me.
Yes ArcSoft works fine, but i guess PDVD's sound quality and DXVA is better or am I wrong?
giosa - PowerDVD long ago removed the ability to play ripped BluRays from a hard drive. Hollywood complained about it and Cyberlink (the creators of PowerDVD) caved in like the little bitches they are. I am not exaggerating when I tell you that every release of PowerDVD has less functionality than the one before it. With each release, Cyberlink takes something away that they used to support in previous releases because Hollywood complains about it.
I think the 7.x versions were the last ones that could play ripped BluRay dscs from a hard drive. The only "fix" that I know of is to find an older version of PowerDVD that had this support. Cyberlink will NOT under any circumstances be willing to supply you with an older version that could do this, so you'll have to use other methods to find it.
To be blunt, weekends are kind of a down time for a lot of us here. I don't always respond on weekends to posts here. Lucky for you on this one. Also, had you done a well crafted web search, you probably would have been able to find out that PowerDVD 9 doesn't support this. Anyway, please be more patient in the future.
Getting a question answered depends on whether someone who can answer it is checking on a given day, and has time to read through numerous posts to find yours. 24 hours is not that long to wait for an answer. The "labor" here is made up of the membership, of which you are now a part, by the way.Originally Posted by giosa
Do you plan on coming here every day for several hours to read and answer questions?
Powerdvd 8 will play blu-ray from the hdd.Also people here on the forums give help as a courtesy and are not required to answer any posts.When posts go unanswered its usually most people dont have the solution right away.
Ben Johnson-I didnt take any stereos!
thanks guys!!
The person I mentioned is also pissed about PowerDVD ... but not for playing Blue Ray.
He has some movies on DVD-HD and PowerDVD wont play them.
What Baldrick said ...
Baldrick Posted: May 10, 2009 05:35
My friend also mentioned same thing .... he uses ArcSoft TotalMedia Theatre to play his DVD-HD disks.
Yup, can confirm that Cyberlink PowerDVD 9 will not play Blu-ray from hard drive, but Arcsoft Total Media Theatre does.
I wish I had found this thread earlier because I just spent the past three days figuring this out for myself through trial and error. First for mounting the BD ISO, I tried the virtual drive in Alcohol 120%. That usually works well for DVD ISOs. That plus PowerDVD didn't work (unsupported disc error). Then I tried mounting the BD ISO in Daemon Tools' virtual drive. Same error with PowerDVD. Then I tried running AnyDVDHD in the background, but still no go. I also tried Alcohol 120%'s virtual drive with Arcsoft TotalMedia Theatre, both with and without AnyDVDHD, but no dice.
What worked was mounting the Blu-ray ISO in Daemon Tools' virtual drive and playing with Arcsoft TotalMedia Theatre. No need, unless you want it, for AnyDVDHD.
You can play HDDVD/bd iso`s using wmp 10 (fu*k wmp 11 or 12 they full of DRM VIRUSES) on winxpsp3. With ANYDVDHD on in the back gound, with K-Lite codec pack 5.00full version and finally FREE RIPPER Alcohol 52% s virtual drive.Sorry I forgot you also need the udf driver 2.5 to handle all those large ISO`s.
Just one more thing about powerdvd9,when you uninstall it .It leaves behind drm viruses that have some effect on some of your pc media caperbiltes.Only way round this is format and dont install any commercial player software. Only free ones because they dont have to kiss anyones arse.Its a BIG FU*KING SHAME about Cyberlink they where realy cool in the dvd revolution.But now they fu*king CR*P.Even their burning software has drm viruses.
Anyway hope it helps.
I have had some success playing Blu-ray ripped to HDD using PowerDVD9. To do this, start PowerDVD 9, then open windows explorer and navigate to the folder that contains your ripped Blu-ray, then drag-and-drop the folder onto the PowerDVD 9 main window. After a few seconds, your movie should start. I just did this with two movies, Doubt and The Soloist. I could not make it work by dragging-and-dropping the ISO image of these two Blu-ray discs; I could make it work only by dragging-and-dropping the folder containing the ripped disc (as described above).
Note, if I try to get PowerDVD 9 to play the movie files from the hard disc, PowerDVD 9 can't seem to find the files (even if I set the directory to exactly where the files are stored). Dragging-and-dropping seems to be the only way that I can get it to work.
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 23:27 -
Can I play RMVB format in powerdvd? why? x2 playback in powerdvd
By fuc847 in forum Software PlayingReplies: 2Last Post: 15th Feb 2007, 21:52 -
PowerDVD won't play files from hard drive
By broadway in forum Software PlayingReplies: 5Last Post: 30th Aug 2004, 12:00 -
Weird PowerDVD problem. When I tried to play DVD from Hard
By crashnburn in forum Software PlayingReplies: 4Last Post: 17th Dec 2003, 17:16 -
Will PowerDVD play a VIDEO_TS folder on the hard drive?
By Jerry in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2003, 12:10
