Results 1 to 16 of 16
    I'm rather on market for tape camcorder, but I still have question about card ones.
    HF10 is older model than HF20, but has bigger sensor (HF10-1/3" vs 1/4" on HF20)
    Is HF20 sensor is better despite that is smaller?
    Main difference is that HF20 is capable of 24mBps recording.
    Anyone?
    thnx
  2. Member edDV's Avatar
    Reviews are lacking but camcorder info is hinting the small sensor is a relatively poor performer.
    http://www.camcorderinfo.com/content...Comparison.htm
    Take a look at the Canon HF S100 for much better performance.
    http://www.camcorderinfo.com/content...view-36389.htm
    http://www.kiva.org/about
    I recently bought the HF200 and did the same comparison. Yeah, the HF200 has a smaller physical sensor but greater density so an overall larger effective pixel count.
    HF200 is capable of 24mbps recording.
    Supposedly, some consider the HF11 better but general consensus was the HF20 is better than than the HF10.
    Consider getting the SDHC only models because of the significant price difference. For me, also easier to pop out the SDHC card than hook up the entire camcorder to the PC.
    I recently too bought the HF200 after debating a lot whether to got for the HF10 or HF200 (same price), but got the HF200 because I simply wanted the newer model. I do see quite a bit of noise when filming indoors in auto mode (better with cinema mode) but I figured I won't be shooting that much in darker circumstances anyway.
    Got a walk-through-my-home video for anyone that's interested on youtube.
  5. Member edDV's Avatar
    Anyone thinking a Canon HF-10 is good enough, check these weekend refurbs on Tiger Direct. Only $250.
    http://www.tigerdirect.com/applicati...&Sku=C925-1448
    I have heard that the motor noise level in this camcorder is rather loud, and noticeable during audio playback-a definite No, No!
  7. Member edDV's Avatar
    If only it had an external mic jack and manual audio level control. But I repeat myself.
  8. Originally Posted by pepegot1
    just what motor is it you hear? they are all flash memory card based recorders.
    My mistake. Confused it with the (HV) MinDV models.
  10. Member edDV's Avatar
    Zoom motor maybe?
  11. Originally Posted by edDV
    Zoom motor maybe?
    hehe - that would be a new one.
    Yes it is zoom motor... its a no no... I heard it for the first time today... and it does go into audio! I dont know how I missed it, but it is very evident now...I have a HF200 bought 6 months ago!
  13. BuskerAlley.com zoobie's Avatar
    Author, Producer, Composer, Director - HC5 HDV, FS-1 SLR
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    Called Canon, they say it's not normal... sending it out to them in Dec after I return from vacation...
    i also got this camcorder 4 days ago, and all that i can say - awesome! i have browse for some reviews and i found it
    if you need some additional info about Canon HF20 camcorder - you can go to http://hf20.net - it helps me to make right choice
    I just bought this camcorder , hence I am here. I found information that made me want to buy it from here for the Canon HF20 . I then went shopping for a discount and found that at www.hf20.org .
    So far the camera has been nothing buy great. I love the sleekness of it and its so portable
  1. Canon HF20 Mts file
    By ggarbis in forum Newbie / General discussions
    Last Post: 6th Dec 2009, 07:52
  2. Canon HF10 -> Premiere Elements 7.0
    By Jone.T in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Dec 2008, 06:21
  3. Canon HF10 - 50i or 25p ?
    By theaterguy in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Nov 2008, 02:57
  4. Canon HF10 NTSC or PAL
    Last Post: 29th May 2008, 12:57
  5. Canon HF10 und Sony Vegas
    By miepel in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Apr 2008, 16:27
About   Advertise   Forum   RSS Feeds   Statistics   Tools
