VideoHelp.com Forum
Results 1 to 12 of 12
    Hi
    I am looking for professional and powerful hardware converter for converting NTSC to PAL and vice versa, can anyone help me?
    I am not looking for software method, because this job is very important and I need the highest quality. Has anyone worked with any hardware converter?
    I appreciate any help in advance.
  2. Member edDV's Avatar
    Originally Posted by Sean_ve99
    Hi
    Normally one would use a service bureau for important PAL transcodes and most often they would be using a Snell and Wilcox converter.
    http://www.snellwilcox.com/products/...n/products.php
    http://www.kiva.org/about
    Thanks for the reply, it seems professional. Are there another suggestion?
    How is Black Magic or AJA?
  4. Member edDV's Avatar
    Do you need to buy one or just get a few tapes converted? Good ones are expensive. Better to use a service bureau.
    Here is a long list of used standards converters.
    http://www.bcs.tv/store/prod_search_...ory_search=570
    At the low end you have the Data Video STC-100 ~$500
    http://www.bcs.tv/store/model_detail.cfm?id=801209
    http://www.bhphotovideo.com/c/produc...Converter.html
    No, I should buy, there are more than 50 DVDs.
    When I searched in net I found some cheap devices for converting NTSC/PAL around 500 dollars but I don’t know if there are good or not.
    I am looking for reasonable price, maybe around 1500 dollars, can I find good devices with this price?
  6. Member edDV's Avatar
    I haven't used the lower price units. Search for reviews.
    Well, if cheap units don’t work well I prefer to spend more. Can you recommend a unit that isn’t very expensive? I really don’t know how much should I spend, I didn’t think Converters are very expensive.
    Hardware will not get you higher quality than the right software, especially if you are starting with DVDs. It may be faster (real time) and easier though.
    If you can't afford the Snell & Willcox, then I'd simply do this: http://www.digitalfaq.com/guides/vid...t-pal-ntsc.htm
  10. converting ntsc to pal ok but in what format vhs>vhs ?
    it's irrelevant in the digital domain imo it's not pal or ntsc it's YCbCr as you may know. All dvd players can play a "pal" or "ntsc" dvd and if you can't you just have to unlock the dvd player.
    TheMaster Rules ;)
    No, many NTSC players will not play PAL discs properly. This is not a region issue. This isn't an issue for the OP though.
  12. Member edDV's Avatar
    True that it is all YCbCr but not true that "PAL" frame rate and line structure is generally supported in western hemisphere DVD players. The cause is the European VAT tax that causes Euros to seek a lower price in less taxed regions. The push back by DVD player manufacturers is region coding and inhibition of 25/50fps and/or 576 lines to make western players useless in Europe or other "PAL" countries. There are exceptions.
    The OP's location "middle east" could describe many format situations. He only offered a need for bi-directional DVD conversion.
    He also says "this job is very important and I need the highest quality" but he also has a low budget.
  1. Throwing Hardware At It
    By doggybs in forum Media Center PC / MediaCenters
    Last Post: 21st Nov 2010, 05:47
  2. Which hardware do I need?
    By A Traveller in forum Linux
    Last Post: 12th Sep 2009, 20:54
  3. new hardware
    By rallynavvie in forum Computer
    Last Post: 20th Feb 2008, 18:43
  4. Hardware Question?
    By Abiyad in forum Editing
    Last Post: 26th Jun 2007, 15:18
  5. best capturing hardware?
    By demonwarrior in forum Newbie / General discussions
    Last Post: 19th Jun 2007, 11:00
