For converting Mkv files to AVCHD format I have been using tsMuxeR, and they come out fullscreen and do not look like any of the original resolution was cropped at all, In fact they look great!
Some of the Mkv files resolutions are AVCHD video compliant(920x1080, 1280x720 and 720x480), and some are not.
What happens to the output files that are not compliant with tsMuxeR?
Iv'e heard that the uncompliant resolutions should be ran thru uncropMKV, which takes a while, before sending them thru tsMuxeR but all of the Mkv files I've done so far Iv'e done with tsMuxeR ONLY(Takes just 10min).
They look great, so is it that the new version of tsMuxeR just adjusts the resolution the the nearest video compliant setting if needed?
Thread: Converting Mkv to AVCHD
If you have downloaded these files and are getting fullscreen (I assume by this you mean it fills a widescreen TV without adding bars) there is a good chance it is because they were pre-butchered when being converted to mkv in the first place, or you have only downloaded 1.85:1 files, and the bars are hidden in the overscan of your TV.
problems converting mkv to avchd
By mattybut in forum Video ConversionReplies: 3Last Post: 22nd May 2011, 00:54 -
Video Pixelation Converting MKV To AVCHD Using TSMUXER
By uscstyle in forum Video ConversionReplies: 26Last Post: 1st Apr 2011, 19:29 -
Subtitles stay too long when converting MKV to AVCHD for PS3 with tsMuxer
By WFlits in forum Video ConversionReplies: 5Last Post: 31st Oct 2010, 05:15 -
Converting mkv to m2ts or AVCHD
By carlosian in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2009, 17:42 -
mov to mkv/avchd
By nirbhayn in forum Video ConversionReplies: 1Last Post: 19th Jun 2009, 14:33
Statistics
Newest guides
Latest tool updates
New media comments
