I had a customer buy a pretty nice HP Vista 64-bit PC. Really nice graphics card, HDMI out. HDMI out is feeding an Epson overhead projector. I set up his whole theater room and chose this PC to be his "HTPC"
It actually does really well and the very simple version of what he wants to do is convert his entire DVD collection (LEGALLY) to his HD for viewing whenever he wants. He does not want to overly compress them so as to keep a good amount of quality. He is more than willing to buy more HD space just as long as the movies look OK.
What I am trying to do for him is find the MOST SIMPLE DVD ripping program that he can do by himself in his spare time. He is NOT very good with computers but he is totally into learning how to use a program if it is simple enough. I am quite certain that if I refer the right program to him he will do fine ripping them once he gets the hang of that particualr program.
Here is the next big issue: I want to find a program that when he gets done, he would not have to do any major "renaming" of the file. EXAMPLE: He will be using Vista Media Center, I would love to find a program that rips the MAIN MOVIE to the HD then when he goes to "My Movies" in MC, there is the title sitting right there ready to start. I need to make this as EASY as possible for him as he has spent a good chunk of change with all the crazy stuff I did in this theater room.
Sorry for the book but I just wanted to be clear in what help I needed! I think its a pretty simple issue but MAN, there are SO MANY programs out there to do this. I should mention again too that this is a 64bit PC, so the program would have to be 64bit friendly. My first impression was to just have him buy the Divx software but last I checked it did not support the 64bit PC. PLUS I think the compression would be too much.
I will end on this: he honestly would not care about copying the ENTIRE .VOB main movie file to preserve the quality but again I just want to find a program that will dump it right into the "My Movies" section of MC where he can go right to it and select PLAY
if u have read this far -THX and please even email me directly with any suggestions
theruckman@gmail.com
To keep it simple, then simply RIP the DVD and not bother with any conversion. DVDFab HD Decrypter will get the job done.
Google is your Friend
You're not going to get 'simple' and 'just the main movie'. I agree with Krispy Kritter, use DVDFAB or AnyDVD/DVD Decrypter, rip in ISO mode. The worse he'll have to do is rename the .iso file to something more meaningful.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
I had no idea that DVD software could play .ISO files? if so, that is great. Will try that. Seems the simplest route.
thx
32-bit program Micrografx on 64-bit windows vista?
By Obamargarine in forum ComputerReplies: 8Last Post: 11th Aug 2009, 19:56 -
Windows Vista: 32 bit or 64 bit?
By vid83 in forum ComputerReplies: 7Last Post: 12th Feb 2009, 04:57 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Ripping my entire DVD/Blu-Ray library for use with HTPC
By Gustar in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2008, 12:01 -
wanting to join and convert files for dvd
By whitenoise in forum Newbie / General discussionsReplies: 26Last Post: 10th Jul 2004, 22:12
Statistics
Newest guides
Latest tool updates
New media comments
